HKS to K&N Air Filter Test Comparisson
Old Feb 16, 2011 | 09:13 AM
satellite's Avatar
Cosworth is dry-type. I've been interested to try it, but there is SOO much BS following these drop-ins around.
Old Feb 16, 2011 | 09:36 AM
gloom's Avatar
Ordered my cosworth drop in 2 weeks ago from Sumopower UK and they have still not sent it, otherways I could have given some feedback..
Anyone know if you need to remove anything around the airbox when changing filters? Havn't tried it out yet.
Old Feb 16, 2011 | 12:58 PM
RideSober's Avatar
Super Street's dyno test on our car showed the K&N filter provided a modest 2HP bump and smothed out the torque curve in higher RPMs.
I have a K&N filter in my car, and if I could spend $42 on another mod that has been proven to add another 2 HP, I would almost certainly give it some serious consideration!
http://www.superstreetonline.com/tec...des/index.html
Even with Mike's doubts as to whether a drop-in would perform based on previous experiences, we actually came out surprised once again as we picked up an additional 2hp and saw a more smoothing effect of the power curve in higher rpm. While a K&N drop-in filter may not work wonders on all Ralliart engines, we were sold and would recommend this as an affordable modification.
Old Feb 16, 2011 | 07:29 PM
Slee256's Avatar
No, I have the Cosworth. You just take the old one out and put the Cozzy in.
Old Feb 17, 2011 | 05:44 PM
rgwinn's Avatar
Just installed a K&N, pop the two clips, pull the old one out, drop the new one in, close the clips.
Just that easy.
Much easier than my other car.
Old Feb 17, 2011 | 07:05 PM
S2K2EVO's Avatar
I have the K&N, I don't know about any FELT increase in performance, but I know the gains are there.
Old Feb 17, 2011 | 07:15 PM
satellite's Avatar
This might get into the same conversations as other forums...buuuuuut...I'm just worried about the oil on the K&Ns.
1. Oil on the MAF = bad
2. Oil slowly drying out over time = no filtering = bad (the K&N relies on the oil to catch particles)
Old Feb 17, 2011 | 07:18 PM
S2K2EVO's Avatar
The filter would have to be soaked in oil for #1 to happen.
Old Feb 18, 2011 | 04:01 AM
satellite's Avatar
Yeah, I do agree with that.
Old Feb 18, 2011 | 04:27 AM
Wasurumo's Avatar
Here ya go guys From this January Import tuner.
look like 21 to crank an about 10 to the wheels
Attached Thumbnails HKS to K&N Air Filter Test Comparisson-baseline.jpg   HKS to K&N Air Filter Test Comparisson-k-n-after.jpg
Old Feb 19, 2011 | 04:14 AM
Mad_SB's Avatar
Originally Posted by zx-319
I'd say it's placebo too...
But if someone can bring some dyno sheet to prove/disprove the benefit of putting those filters that would be nice.
https://www.evolutionm.net/forums/ev...-vs-works.html
Enjoy, that was my X the testing was done on. In short, various filters do make power, they way they do so is as much to do with altering the flow around the maf element which in turn leans out the mixture (because the ecu see's slightly lower load).
Old Jul 15, 2011 | 03:01 PM
ukrboy's Avatar
just installed K&N drop in last night.
Do you need to re-map the ECU?
Old Jul 18, 2011 | 01:03 PM
Dr1fter's Avatar
I'd personally recommend a dry filter...as I ran the K&N in my ralliart and ended up having to replace my MAF sensor because of it
Old Jul 19, 2011 | 07:05 AM
ukrboy's Avatar
was that because of oil on it?
Old Jul 19, 2011 | 08:14 AM
lancer0220's Avatar
that would only happen when you dont properly oil it. I have had a k&n drop in in both my lancers, toyota tundra (dads), scion tc (fiances car/my car), chevrolet blazer (brothers) , oldsmobile bravada (brothers) and have had 0 issues when re-oiling my filters.
Currently I have an AFE DRY filter though in my gts because I got it for real cheap and it came with a cleaning kit (k&n kit ran out with all those k&n filters we have).
