Display?
Old Mar 4, 2011 | 01:26 PM
EyeDreamt's Avatar
Originally Posted by pbassist12
Let me know how it works and the pricing and stuff!
Its definitely not a plug & play solution, but it gives you a ton of features for a relatively low price.
Alltogether I have spent around $800 inluding all the little odds and ends and materials for fabricating the screen into the dash bezel. Here is what my setup consists of:
  • 7" Touchscreen Monitor
  • M2-ATX Power Supply (starts computer when car turns on, shuts it down safely when car turns off)
  • Motherboard & CPU
  • Laptop Harddrive
  • Voom PC-2 Case
  • Aftermarket Dash Kit
  • USB Wireless-N Adapter
  • USB GPS receiver
  • Webcam
  • Griffin PowerMate (Sweet control knob)
  • Bluetooth USB Adapter
  • Tactrix Cable & Right Angle extension
I had an aftermerket headunit from my old car that I will be using to run all the audio through and for radio. Some people choose to forgo a HU all together, and in such a case, you wouldnt need to fabricate a dash panel as there are double-din pc touchscreens out there.
Like I said, this is no plug and play solution. I have spent hours upon hours setting up software, etc, and I plan to spend about 3 hours wiring up the car the way I will want. The advantage is there is truly no limit to what you can do. There are people running projectors out of their headlights, controlling neon, airbags, ac & heat, etc all with computers in their car. If your into building things yourself, and like computers & cars, its definitely a hobby for you. I'll post more pics in another thread once my install is all done.
For more info on carPCs hit up http://www.mp3car.com.
Old Mar 4, 2011 | 08:58 PM
gloom's Avatar
I have prepared myself a bit to integrate a laptop into my car come spring time. I will use my existent touch screen to start with. Hopefully the 800x? res will work out ok with s-video. I won't have touchscreen support with the laptop which will be a bummer but will maybe move on to a real car pc solution in the future. Was thinking about making a non restricted menu system in visual basic to load evoscan, winamp and more.
  • Motherboard & CPU
  • Laptop Harddrive
  • Voom PC-2 Case
  • USB GPS receiver
  • Webcam
Old Mar 5, 2011 | 02:41 PM
EyeDreamt's Avatar
I like the menu idea. I'm actually working on creating an Adobe AIR app that will do something similar, but also play my music and show me a google map of my location through GPS.
