what does this methanol injection kit do
Old May 11, 2011 | 05:29 PM
newmitsuowner's Avatar
wondered about this.
http://www.maperformance.com/aquamis...m-806-086.html
im not really to familiar with it, but does it take over the normal engine? no more gas or what does it do exactly? more horsepower as well?
Old May 11, 2011 | 05:31 PM
total0wnage's Avatar
idk much about it either but what i know is that it is a separate tank you setup and pumps meth into you gas, basically creating higher octane. you will gain horsepower im not sure how much or anything.
Old May 11, 2011 | 05:54 PM
NFSLancerRA's Avatar
OP, you don't want it.
Old May 11, 2011 | 07:19 PM
yeah i wasn't going to get it i was just curious about it
thanks
Old May 11, 2011 | 07:32 PM
erald01's Avatar
you dont need meth, with the intro of e85 meth is becoming useless and it can also be dangerous...meth is used as a booster to your fuel ( to raise the octane level) to run aggressive timing, more boost and it helps by reducing detonation or knock in this case...if meth spray fails then your engine fails, and a lot of people have found out the hard way.
Old May 11, 2011 | 07:53 PM
RideSober's Avatar
Ditto the remarks above. A few years back for big power forced induction motors, meth or alcohol injection was the ticket to achieving higher octane without just running pure race gas. Running injection would allow significantly more boost, and of course could generate higher horse power. I investigated the idea for one of my big block supercharged motors and found out that there were just too many catostrophic failiures to take the risk.
Agreed, E85 seems to be a much safer path to achieve a some what similar result.
esevo
43
May 31, 2015 05:55 AM
RSGuy
AEM EMS
Apr 11, 2011 12:18 PM
maperformance
Sep 7, 2010 01:39 PM
vroomevo
Sep 14, 2008 10:35 AM
Blue Evo 8
Automotosports - Illinois
21
Sep 3, 2006 02:20 PM
