little help with vaccum/boost
Old May 23, 2011 | 11:17 AM
Cesarn2928's Avatar
So i installed my Boost Gauge few weeks ago... but my ralliart at idle is showing -10! (vacuum) is that normal..?
my friend says it should be around -16 to -20 but idk... i rther ask RA ppl... lol
any comments?
Old May 23, 2011 | 11:25 AM
nunyas's Avatar
10 vacuum is about normal for the RA. My data logs show about -9 to -10 psi at idle...
Old May 23, 2011 | 11:32 AM
adog's Avatar
Really?? Mine shows -17 cold -19 warm and -21 hot. I taped into the line right before the bov, maybe that has something to do with it?
Old May 23, 2011 | 11:37 AM
TOralliart's Avatar
Mine is the same.
Old May 23, 2011 | 11:41 AM
Cesarn2928's Avatar
so whats normal? lol -16 to -20 rite? and if it is... how come my is -10? u think i got leaks or something? how can i found out if i got leaks?
Old May 23, 2011 | 11:42 AM
Cesarn2928's Avatar
mine does the same.. but i dont think its normal...
plus when my A/C is on... it goes to -8.
Old May 23, 2011 | 05:31 PM
RalliMark's Avatar
Mine sits at 16 in Mg at idle. 21 in mg when letting of the gas.
Old May 23, 2011 | 06:52 PM
nunyas's Avatar
it's normal to be at -9 to -10 at idle with no accessories turned on... it's been discussed many times on these forums. A quick search of the 09+ Ralliart Engine/Turbo/Drivetrain train sub section shows one of the most recent discussions we've had...
https://www.evolutionm.net/forums/09...-pressure.html
When you turn on the A/C the throttle by wire system over rides your Accelerator Pedal Position sensor, and opens up the throttle a little to compensate for the extra drag the A/C system puts on the crank...
Also, the vacuum you read on your gauge will be depend on where you're tapping into the system. The idle vacuum level that I stated comes from the car's built-in boost sensor, which takes it's readings off the manifold (vacuum line in the front ... highlighted here ). You'll want to have your boost gauge read your boost/vacuum from the same location as the stock boost sensor. Taking your readings from a different location won't let you know if the car is reading boost or not and could lead to major problems (i.e. your boost gauge reading 18PSI when the boost sensor reads 0 or less)...
Old May 23, 2011 | 07:44 PM
Cesarn2928's Avatar
yeh my hose is on that location... for my boost/vacuum read out....
so it is normal to have it at -10? ? because and how can i find out if i have a LEAK somewhere?
Old May 24, 2011 | 04:15 AM
Mad_SB's Avatar
any comments?
-10 what? psig. kpa, inhg, mmhg.... units make all the difference
Old May 24, 2011 | 04:39 AM
Cesarn2928's Avatar
the mercury thing i belive.
i asked glowshift maybe if it was PSI.. cuz if it was then the convertion was good -9 = around -18 or so..
but they said Mercury something idk... unless dat dude didnt kno n said mercury just so i can shut up lol
