what is your dyno for this setup?
Old Jun 22, 2011 | 07:53 PM
KeDoSH's Avatar
does anyone have a setup with a TBE,DROP-IN FILTER, and FMIC? if so what do you have it DYNO'd at?
Old Jun 22, 2011 | 09:02 PM
RideSober's Avatar
While there should be little doubt those mods alone can allow the motor to make more power than stock, IMHO, I think the skill of the tuner might be the most important factor to consider.
Old Jun 22, 2011 | 09:13 PM
npham455's Avatar
Purely a guess from other dyno sheets I've seen, 250hp/280tq would be a good estimate. But if you are not tuned, you won't see these numbers.
Old Jun 22, 2011 | 09:16 PM
initial_d2k's Avatar
untuned catback and dropin:
http://www.superstreetonline.com/tec...oyo_tires.html
Old Jun 22, 2011 | 09:44 PM
aaronk's Avatar
I have those mods and I put out 260/320 at the wheels
Old Jun 23, 2011 | 03:19 AM
KeDoSH's Avatar
So I won't see a difference if I go with a bigger fmic? I have stage 2 now.
Old Jun 23, 2011 | 09:23 PM
AntiBlitz's Avatar
aaronk, not to go off topic, which i totally am, but why in the hell is your Torque so much higher then your HP?
and to answer the op's ?, im sorry i do not have this setup however with the mods i have im pushing 308/290.
X Turbo 23psi
UR LDP
UR HFC
UR CBE
UR UICP/LICP
UR FMIC
Megan Exhaust Manifold (it looks nice but i think im going to get CBRD's EM once i have the funding)
3 port peirberg Boost controller
HKS BOV Recirc.
CBRD Custom SRI W/ Velocity Stack
Dyno'ed by CBRD Skimpy Mustang dyno
Old Jun 23, 2011 | 09:42 PM
nunyas's Avatar
I'm gonna guess that he's on the stock RA turbo. The stock RA turbo has enough peak boost to make over 300 torque, but it can't sustain the boost into the higher RPMs where the top end HP is. Basically his power curve, torque peaks between 3k and 4k, and falls so quickly after that the HP either flattens out after 5k or falls slightly... essentially, it looks similar to my power curves, only with higher peak values:
it's like that because the stock turbo can't sustain the higher boost levels out to red line...
I basically have the mods the OP has listed...
Drop-in K&N filter
EvoX FMIC
UR UICP
Magnaflow cat back
UR down pipe (stock cat though)
Old Jun 24, 2011 | 09:19 AM
ltn's Avatar
ltn
Nunya, are you on a 91 tune? Hopefully I can't get those numbers when I get my HFC and my FMIC installed with a new tune.
Old Jun 24, 2011 | 09:29 PM
user 7082023424's Avatar
I have similar mods and made 250hp. Bigger intercooler won't make more peak power, but it will flatten the power band and provide more power across the rev range.
Old Jun 24, 2011 | 09:44 PM
Exyia's Avatar
the stock RA turbo is an excellent example of how dyno numbers aren't everything
whatever number you aim for, if it's over 280, it won't hold for long. the turbo is THAT small. your powerband will still be narrow as hell and the peak numbers will mean less and less
Old Jun 24, 2011 | 11:41 PM
aaronk's Avatar
X Turbo 23psi
UR LDP
UR HFC
UR CBE
UR UICP/LICP
UR FMIC
HKS BOV Recirc.
Exactly like Nunya said, stock turbo
Old Jun 25, 2011 | 08:46 AM
SudzRA's Avatar
On a *very* conservative self tune on 91oct, I'm making 263whp/285wtq with the mods below, according to the average of 3 runs using VD (dynojet). I'll be doing a few tweaks to the tune with Bryan's (Razorlab) help.
Old Jun 25, 2011 | 09:41 AM
nunyas's Avatar
yeah, I'm running 91 Oct...
jnut24
Mar 8, 2017 02:42 PM
MR ArcticC
Aug 8, 2016 06:41 AM
240Z TwinTurbo
Nov 9, 2015 03:17 PM
Ludikraut
Sep 1, 2005 04:21 AM
