Ralliart Reliability
Old Aug 15, 2015 | 12:18 AM
  #46
DWILSON357's Avatar
Guys arguably the most important thing about warming your car up isn't so much about heat (it is don't get me wrong) it's about establishing oil circulation. Fwiw my old man's been a trans mechanic for 30+ years...he let's the car idle for 2-3 minutes, won't beat on it until it's ran for 10...normal driving not working the motor hard I'd ok in between.
Old Aug 15, 2015 | 04:23 PM
  #47
SharkyPR's Avatar
Originally Posted by zeRep85RA
Sport Mode = Quicker Shifts
Quicker Shifts = Less Slip
Less Slip = Less Heat
Less Heat = Longer Life
I always used sport mode...
I had about 89,000 miles before my RA got totaled. @ 267awhp/289awtq
z
E
R
E
p
You forgot these two
Sport Mode = No Cruise Control
Sport Mode = Lower MPGs
Old Aug 16, 2015 | 05:46 PM
  #48
Slee256's Avatar
That's not true if you drive in Sport MANUAL. You'll only get lower MPG's if you drive in Sport AUTO.
Old Aug 17, 2015 | 01:26 AM
  #49
AlDim's Avatar
Exactly. I use S-Sport all the time and fuel economy is exactly the same as with Normal or Sport. Normal is only useful for the cruise control.
Old Aug 28, 2015 | 01:33 PM
  #50
Senvae's Avatar
Just wanted to help and chime in. I'm also from Edmonton AB, and I have a Ralliart 2009 with over 170000km on it. Transmission still works, even with aftermarket liquid in it. No issues with the tranny at all and I am the second owner. I have reasons to believe the previous owner also drove it pretty hard since it used to have an exhaust from the bowels of hell installed on it. (Had to get rid of it, I couldn't justify that brutal sound to the wife... the same wife who had no problems with a Borla exhaust on a previous one we test drove).
I did, however, make a deal with the dealer to replace a broken AWC center pump. That pump can cost over 2000$ to repair at the dealer. Some people here say it's just broken seals which can be done for about 400$ at a local repair shop, but I didn't try that yet. The center pump unit has issues with Edmonton's -30C days. You'll need to keep it in a garage or give it time to warm up before driving. Also, the older Ralliarts had bad fuel pump relays. There are links in these forums on where to buy the newer/better ones.
Old Aug 31, 2015 | 04:30 PM
  #51
zeRep85RA's Avatar
i heard waiting too long can actually be bad..
Warm oil but cold tranny.
Most people just keep the rpm below 3k until warm up and seem to be fine.
zeRep
Old Oct 3, 2016 | 07:53 PM
  #52
strykr's Avatar
Veteran: Canadian Forces
How long do you usually wait just till temp gauge moves? Just wondering because I just picked mine up and sadly have no garage
Old Oct 5, 2016 | 11:31 AM
  #53
russ72's Avatar
Most of the time I let it run for maybe 30 seconds or less sometimes and go, but I don't really drive hard until the temp gets a few bars up. Winter might be a different story, I may let it warm up a little longer, but again I still wont drive hard until temp gauge is a few bars or more.
I will also try and let the car run a minute or two after driving before shutting it off, especially if I do some hard driving.
So, far my tranny is doing okay, it's about due for it's 30k mile change though and should help the shifting experience.
Old Oct 5, 2016 | 11:49 AM
  #54
strykr's Avatar
Okay perfect, that's something I already do.
c08
Apr 16, 2017 08:07 AM
truxx
Jan 22, 2017 09:10 AM
brandonboggs
Oct 11, 2016 05:52 AM
sweimert02
May 9, 2016 05:49 PM
bdean531
Mar 18, 2016 06:32 AM
