Quantity of Plasti Dip Required
Old Sep 6, 2011 | 06:54 AM
Jasoob's Avatar
Hey everyone,
To anyone who's Plasti-dipped their rims/painted the chrome trim around the car:
How many cans did you require? It seems the aerosol is the easiest way to go...
I'm roughly guessing it would be about 5-6 cans total for the above.
Just wanted to double check with everyone.
Old Sep 6, 2011 | 12:23 PM
Veronica's Avatar
DO NOT buy the can - get the aerosol only.
i expect one can is sufficient for the trim.
Old Sep 6, 2011 | 12:33 PM
DaJackson's Avatar
For wheels and trim you'll need 2. Unless your planning on doing a bunch of coats then you'll need 3.
Old Sep 6, 2011 | 04:09 PM
Snipingdude's Avatar
I used 1 can for the chrome ring...I even had enough to do my chrome window inserts as well
Old Sep 6, 2011 | 04:57 PM
total0wnage's Avatar
roughly 1-2 cans for chrome ring and window trim, id guess 3-4 for wheels
Old Sep 7, 2011 | 10:28 AM
Veronica's Avatar
But strongly consider powder coat for the wheels.
Old Sep 7, 2011 | 11:03 AM
Jasoob's Avatar
Powder coating would be great but it's about $600-$800 with prep, etc...
Plasti Dip is like $50 for a case.
I noticed on my '11 Sportback Ralliart, no chrome trim around the windows! Only the front to do.
I found a supplier in Canada and I have to order (1) case which is (6) cans. I'll do my rims and whatever else.
Thanks everyone.
Old Sep 7, 2011 | 11:06 AM
escodotcarter's Avatar
I wonder if it would throw the balance off on the wheels ?
Old Sep 7, 2011 | 11:39 AM
Jasoob's Avatar
No, it doesn't weight enough...I've never heard of anyone mentioning that. Also, if it's applied equally, it should create any imbalance.
Old Sep 7, 2011 | 01:32 PM
velocityhead's Avatar
One can of aerosol was enough to do my ring twice and all of my window trim once.
Old Sep 7, 2011 | 01:42 PM
600-800!!!! where are u getting you quotes, most places do like $60/per wheel and the most ive ever seen in $120/wheel which still only comes out to 480.
Old Sep 7, 2011 | 01:46 PM
FTY Motorsports's Avatar
60/wheel is the norm unless u want like time attack 2 color stuff then its normally 100/wheel around here in socal
Old Sep 7, 2011 | 07:48 PM
p1llar's Avatar
Since we are on the plastic dip subject, do you guys remove the chrome trim of just mask it off?
Is it just held in by clips?
Old Sep 8, 2011 | 12:11 PM
Veronica's Avatar
To properly remove the trim ring you have to take the front end off. Easy, but time-consuming (see the how-to). I think the time to mask would still be less/easier. But i have not done either - so i too, eagerly await the answer
Old Sep 8, 2011 | 12:45 PM
If you're not familiar with removing the bumper, then masking it off and spraying directly on the car will be faster.
After you've had the bumper on and off a couple times, it goes fast. If you spray the ring off the car, you won't miss any spots due to poor masking.
