vibration @70-80mph...
Old Oct 6, 2011 | 07:21 AM
dyck888's Avatar
i'm not sure what's wrong with my RA... the steering wheel vibrates between 70-80mph speed (very small amount of vibration). i tried to have all the wheels balanced and do the alignment at belle-tire but still doing the same thing.
Old Oct 6, 2011 | 07:22 AM
eusgen's Avatar
I have the same problem in my 02 OZ Rally
Old Oct 6, 2011 | 08:18 AM
richardjh's Avatar
It does still sound like a wheel-balance issue... albeit a minor one.
Find a perfectionist at a tyre shop, and challenge them to give you a perfect wheel-balance!
Rich
Old Oct 6, 2011 | 01:29 PM
lancer0220's Avatar
aftermarket or OEM wheels.
if aftermarket
-make sure you have hubcentric rings
-aftermarket wheels tend to need to be balanced just right
-if they are cheap wheels check for any minor bends
if OEM
- most likely its just a bad balance, take it to a good shop and tell them you need the balance to be 100% perfect else they will have to keep redoing it until it solves the issue.
-check for bends
Old Oct 6, 2011 | 03:47 PM
RA173's Avatar
Get them Road Forced Balanced! problem solved
Old Oct 6, 2011 | 10:04 PM
zebra4's Avatar
I had the same problem on my 05 Ralliart. I went through countless balances at different places. Turns out one of my tires had wore funny, and although i couldnt tell by looking at it, it was causing my vibration. I put new tires on and never had a problem. Just sharing my experience, i'm not saying that is your problem.
AlexDRS94
Apr 14, 2015 04:37 AM
elhuberto
Sep 13, 2013 04:45 PM
hattackk
12
Apr 4, 2013 08:31 PM
Sunset350ZR
May 25, 2012 04:35 AM
ThEHiTMaN
20
Sep 30, 2004 06:30 PM
