Improving 1/4 mile time for ralliart?
Old Dec 12, 2011 | 08:12 AM
  #31
baggelis's Avatar
last summer i went to the drag strip and my best time was a 12.7 @108.59mph with the stock tires and my best 60ft was a 2.0 and i was using the brake boosting method next summer im getting some better tires and im gonna try the tap method it seems to work better for alot of people
Old Dec 12, 2011 | 09:26 AM
  #32
badreligi0n's Avatar
I wish there was a track near me :/ . I guess i wont ever know what my current set-up can run in the 1/4. I would bet pretty good hopefully!
Ill never know becasue I am installing a few goodies (FP Red, GSC2 Cams, and other supporting mods) this winter :].
Old Dec 12, 2011 | 02:34 PM
  #33
masafina's Avatar
do the tap method with the same tires, you dont want xtreme grip. Something can break
Old Dec 12, 2011 | 03:30 PM
  #34
RalliMark's Avatar
Originally Posted by 03chi-town0Z
Managed a 12.582 this weekend. Still on stock RA turbo. Blip the accelerator a couple times til the lights start to drop. Then hold the pedal to the floor. Let off the brake at the last yellow and away we go. Usually between 1.73-1.79 60' times. Very consistent. I have a video ill upload later hopefully. I also have another of me squealing the tires on launch, too, though I'm sure that's been seen before
I wanna c a video of how u do it. On my first run ever I did the same method as you say up there and I went into limp mode and it took at least 20 secs to come out of it. I was afraid to try again of fear of going into limp mode again so I just did the tap method just up to 2000rpms until the final light and just floored it. I couldnt get a good 60' (best was 1.96) with that method and made my time suffer. It may not have help that I drove about a half hour to the track right through tech and then right into the staging lanes. I could feel a hugh difference in my first launch but like I said I was afraid of going into limp mode and hurting my trans. You think it was just because the trans temp was already high?
Old Dec 21, 2011 | 06:12 PM
  #35
hatke147's Avatar
so i got a question i was reading all through this and i am trying to learn how to better launch my RA and i see you guys saying use the Tap method meaning taping the gas while holding the brakes to get the RPM's up above 3k and when i do that i get a loud popping noise coming from the engine and im not sure what it is or if its bad or if anyone else has experienced it but i have only done it twice and both times it did it so im not gonna do it any more until i fond out what it is and if its bad...
Old Dec 21, 2011 | 06:44 PM
  #36
03chi-town0Z's Avatar
From the engine or from the exhaust? What mods (if any) do you have? The car has a habit of backfiring/afterburning when you do this and have a test-pipe installed.
Old Dec 22, 2011 | 12:40 PM
  #37
pbassist12's Avatar
This is true. Sometimes when I'm daily driving ill get a pop from my exhaust. If its from the engine then idk
Old Dec 25, 2011 | 10:47 AM
  #38
Here's a quick example of the launch technique that I use. It's a quick tap, tap, tap once I'm staged and as soon as the lights start dropping, you can hear me holding the pedal to the floor. When the last yellow comes on, let off the brake and away I go.
The 60' on this pass was something in the low 1.7s (can't find the slip right now) and the ET for the 1/4 wasn't exactly my best, but it was fairly decent and is a good example of how quick these cars can get out of the hole.
Devin @ Boostin Performance should have another video, from directly behind the car while launching, so I'm going to try and get ahold of that, otherwise hopefully next season I can get some videos a little closer to the car so you can hear/see it a little better, but at least it's something for now.
http://youtu.be/tYbG7aECzv0
Old Dec 25, 2011 | 11:25 AM
  #39
pbassist12's Avatar
Awesome kyle! Cant wait to hit up the drag strip with you this season! Do you ever get the slow down alert cause i read that some people do
Old Dec 25, 2011 | 12:24 PM
  #40
Funny you ask that...
http://youtu.be/pMqbIADtgig
Old Dec 25, 2011 | 05:52 PM
  #41
pbassist12's Avatar
haha damn does it just stop you or what?
Old Dec 25, 2011 | 06:12 PM
  #42
See the front end of the car nose-dive just after the start? Car just falls on its face and stops accelerating. Like if you just let go of the pedal, even though you're still pushing it to the floor. Then, all of a sudden, it comes back like nothing ever happened and away you go again.
Old Dec 25, 2011 | 06:18 PM
  #43
pbassist12's Avatar
What causes it to do that? Any way around it??
Old Dec 25, 2011 | 06:42 PM
  #44
masafina's Avatar
Welcome to the ralliart world
Old Dec 25, 2011 | 08:21 PM
  #45
pbassist12's Avatar
I still haven't gotten it in my car so lets hope that doesn't happen.
