Fuego's Project Car!
Old Sep 5, 2013 | 03:05 PM
  #286
Ralliart915's Avatar
Man saw your car on Kenworthy again dude it's looking more and more clean. I was the guy in the red evo x that honked lol.
Old Oct 22, 2013 | 03:31 AM
  #287
ChaosSoldier's Avatar
Old Oct 11, 2016 | 01:27 PM
  #288
Fuego's Avatar
Thanks everyone! Sorry for such a late reply. I have not been on here for a very long time. Just a quick update. The car is running great and I painted all the carbon fiber black. The carbon fiber took a beating because of the heat. I actually like the black look and maybe later today I will take a picture of it. The transmission is holding up well after almost 4 years. I did change my headlights but I think that's about it.
I'm getting ready to do some stuff next year. I will post when time comes.
Old Oct 11, 2016 | 02:06 PM
  #289
Fuego's Avatar
Not clean though, has a light layer of Dust
Old Oct 26, 2016 | 08:09 AM
  #290
Fuego's Avatar
Here are the headlights I currently have on: Anzo USA 121428 Black Halo Projector Headlight with Clear Lens and Amber Reflector for Mitsubishi Lancer
Old Oct 26, 2016 | 08:24 AM
  #291
Fuego's Avatar
My Transfer Case is dying. I ordered a used one and it should be here soon. It's used but has 36k miles and I got it for $650.
I notice some issues with my suspension. A lot of boots leading from the axel and the control arms. I got CV joint boots for all the axels, total of 8. Got a ball joint for the lower control arms and some whiteline parts that I will be installing also, wish they had everything I needed as a product.
Whiteline KLC163 - Front Sway Bar Links
Whiteline W53382 - Front Lower Control Arm Bushings - Inner Rear Position
Whiteline W0593 - W0593 Front Control Arm Bushing
Ordered some Nylon And Stainless Steel Braided Fuel Oil Gas Line Hose Black because some of them are starting to look bad on the car and some High Temperature Silicone Vacuum Tubing Hose.
Will be ordering a new transmission radiator fan as my fan is DEAD.
That means when I get to the shop, it will be a busy day.
Old Oct 26, 2016 | 08:52 AM
  #292
Fuego's Avatar
Future Plans:
Turbo: A kit for the BW EFR 8374, not sure who I will get the kit from yet and have not decided IWG or EWG yet.
Transmission:
Get my transmission a full and complete Overhaul and new clutches. It will be done by Kozmic Motorsports and this is what will be done:
Overhaul, Getrag DCT470 (SST) Transmission. Includes Overhaul kit, all filters, labor, fork 4 repair, clutch set up, VB bore plug upgrades, Dyno Testing, Coding, Teaching, Vin Writing, and other computer related functions requiring a MUT3 tool . Clutch Module Kit, 10 Disc, DCT470 (SST), includes steel plates and R series pistons OEM Diaqueen SST Transmission fluid. Plus the Dodson Heated Sump Kit.
Others:
K27 Catch Can or Driven Catch Can.
Get the new sets of fuel pump relays.
Fuel Pump: Walbro 450
MAP Stud Kit
GSC S2 Cams, and head ported by HeadGames Motorworks 4B Pocket Port “R” Package 031
Intake Ported w/ mil.spec tb
Block Info Coming Soon.
Old Oct 29, 2016 | 08:31 PM
  #293
Fuego's Avatar
Ok currently planning to do a relocation of battery to the trunk. I'm planning on a decent sound system and I need to relocate the battery so that I can have a full size.
For the trunk:
Optima Yellow Top 34/78 Battery
Optima Billet Battery Tray Racing Race Trunk Relocation Box Hold Down
Military Spec Battery Terminal Top Post Kit
2 AWG Flexible Welding Cable Black and Red
For Engine Bay:
Part Number: 8571A017 (Joint Wiring)
Part Number: 8571A018 (Fusible Link Cover)
Part Number: 8571A019 (Fusible Link)
Custom bracket to hold the joint wiring box
Currently this is what I plan to order.
Old Nov 10, 2016 | 04:34 PM
  #294
Fuego's Avatar
Bunch of stuff came in!!!
MAP investment Cast manifold coming.
Walbro 450 kit by kozmic is in
Transfercase is in
More whiteline suspension parts and other suspension parts
New fuel lines
New vacuum lines
XS Power D925 battery, cables and everything to mount it in the trunk.
Fuel relays
New CV boots for all the axles
And all the stuff for a full service.
Once everything comes in I'll add the part #s to page one.
Might get a retune after.
Next year I hope to do the transmission upgrade, Turbo upgrade and audio.
Jhurley_EvoVIII
Sep 11, 2015 07:22 AM
Pr3z
For Sale - Cars For Sale
14
Aug 28, 2009 06:02 AM
EvoIXMR
Apr 23, 2007 02:16 PM
