Gst or ams?
Old Nov 3, 2011 | 06:53 AM
Frank120's Avatar
Gst or ams?
I want to get my ralliart flashed should I do the gst and boost pill or ams stage 0? I live 40 minutes from ams. Oh and I have a UR performance muffler on the way. Any help will be appreciated.
Old Nov 3, 2011 | 06:58 AM
2muchboost's Avatar
Making a donation to Brian @ GST for the RA base map is WAY cheaper then getting custom tune.
If you plan on only doing that performance muffler then GST base map is the route I would go.
If you plan on adding more parts then you should definitely have a custom tune, in that case go with AMS.
Good luck!
Old Nov 3, 2011 | 07:25 AM
Frank120's Avatar
Good luck!
Is it easy to do the gst one? That has alot of pages to read through. And how reliable is it?
Old Nov 3, 2011 | 10:56 AM
nunyas's Avatar
that all depends on your technical ability
If you're afraid to or consider beyond your technical ability to hack your phone and install a custom ROM, then you may want to rank going to AMS higher than installing/flashing the GST tune to your car yourself
Old Nov 3, 2011 | 12:08 PM
2muchboost's Avatar
Its not terribly hard. Here is a good "how to" video.
Good luck!
http://www.youtube.com/watch?v=AigoMPNtqAA
Old Nov 3, 2011 | 12:29 PM
whtrice's Avatar
Veteran: Air Force
You will actually learn a ton more if you do it yourself as apposed to have someone else
do it ........... that is not a bad thing.
Old Nov 3, 2011 | 02:58 PM
RalliMark's Avatar
Go see Devin and Boostin Performance if your going to get a custom tune and you live in Chicago.
Old Nov 3, 2011 | 05:09 PM
03chi-town0Z's Avatar
I already sent you a PM with my thoughts between the two, but like Mark said, if you end up deciding to just have it done by a professional, go check out Devin.
cmb70
Oct 4, 2015 10:49 PM
pbassist12
14
Mar 7, 2011 08:48 AM
EvoOtto
Sep 8, 2010 08:01 PM
