EvoX stock intake on Ralliart?
Old Dec 16, 2011 | 12:44 PM
BravoZero's Avatar
Originally Posted by EyeDreamt
Let me know when you do that. I'll happily help. That lower IC pipe can be a *****.
You got it. Heading to MD on Sunday hopefully to pick everything up. Need to get a coupler for the turbo outlet pipe and a metal pipe for the BPV outlet.
Old Dec 16, 2011 | 06:01 PM
pbassist12's Avatar
BravoZero hows the K&N filter working out for you? haha
Also Im thinking of going with the AEM intake for my evo x swap
Old Dec 16, 2011 | 06:08 PM
BoostBuddyGSX's Avatar
curious to see if this works!
Old Dec 16, 2011 | 07:54 PM
BravoZero's Avatar
Filter's fine, it's in my gf's ES. I bought one brand new right after I got my RA.
If you're doing an X swap, then I can see an aftermarket intake, or just a larger intake in general, having some decent benefits.
One of the things Mitsubishi got right for this car was the stock intake, because it's specifically designed for the limits of the small turbo. Anything bigger just isn't worth it since it won't net any noticeable gains.
Old Dec 16, 2011 | 10:22 PM
Exyia's Avatar
Have you taken a glance at the Modding sticky?
https://www.evolutionm.net/forums/09...g-your-ra.html
Intakes
This is probably another huge mis-understood concept across both RA's and Evo's
The purpose of an intake is to feed the turbo air to compress. NOTHING more.
An intake does not help spool - the exhaust gases control the spool rate of the turbine and compressor wheels.
Turbo's that are not being fed enough air to match how much it needs to compress at higher rpms can face a restriction with the air intake. But with the case of the Ralliart, the stock turbo is VERY small. Since the flow of the turbo is very limited, there's no huge power gains to be had from an intake on the stock RA turbo.
An upgraded drop-in filter that helps flow a little more is enough for most RA owners. When you have upgraded the full exhaust, the stock RA turbo might run into some restriction by not getting fed enough air, but this margin is very small overall.
But this intake claims/shows to make XX amount of power?
Most intakes are showing gains off a stock car and stock tune. The factory tune's mixture of air and fuel (AFR) is so rich on fuel, that adding more air will always increase power.
The problem is that the main purpose of tuning involves optimizing fuel trims and AFR's. Buying an intake to change the AFR's is essentially doing the job of a proper tune - but with less control and less optimization than obviously directly changing fuel trims in a tune.
So you're back to the pure purpose of an intake - to feed air to the turbo. This is why most intakes actually don't show much power gains AFTER a tune compared to a drop-in filter. The turbo will not compress more air past it's capacity, no matter how much air is being fed to it.
And remember, the stock RA turbo is SMALL. You will run into restrictions on the turbo's flow rate much sooner than the intake's ability to feed it air.
as for possibility, it's possible with the right sized couplers and/or some piping - but once you truly understand the purpose of an intake (as merely an air feed for the turbo kind, nothing else), it kind of spoils the desire to even do it
hope this helps
bhaikalis
Dec 24, 2015 05:31 PM
TheNEWB
25
Sep 6, 2014 02:17 AM
skills
May 4, 2013 05:07 PM
Jasoob
51
Dec 19, 2012 07:09 PM
velocityhead
Oct 4, 2009 06:36 PM
