Woot! Lowered!
Old Jan 20, 2012 | 08:50 AM
CurseDSM's Avatar
Originally Posted by Veronica
A nice and noticable improvement in already great handling.
Needs an alignment. Is the rear camber adjustable? I worry the inside treads will wear waaay too quickly...
Some clunking and grunking as it settles so i need to check torques (especially the end links) when i swap wheels.
If you let it go sure it will tear the tires up. If you get it aligned within a day or so you should be fine. I am not sure about the x but I know I have the engles kit for the rear for my evo.
Old Jan 20, 2012 | 02:05 PM
nunyas's Avatar
No, the camber is not adjustable on the front or the rear in stock form. You'll need a camber kit to adjust either. AFIAK WhiteLine is the only company that makes a camber kit that will fit our rear suspension:
http://www.whiteline.com.au/do_segue...cle=10%2F08-ON
Old Jan 24, 2012 | 12:33 PM
Veronica's Avatar
^Excellent! Thank you so much!
