Funny Story
Old Feb 13, 2012 | 03:20 AM
richardjh's Avatar
Originally Posted by OverCorrupt
"Check yoself befo you wizzitywreck yoself!" to lock it. Then final step 3 get a surgeon to install it in your lets say, left butt cheek.
*******, now I've got to change my butt-cheek passphrase. We can't both use that!
Rich
Old Feb 13, 2012 | 04:07 AM
OverCorrupt's Avatar
Rich
haha sure we could, we could make some team called The "A" Team, besides it would be Double Penetration Protection!
Old Feb 13, 2012 | 04:39 AM
richardjh's Avatar
Unsubscribe! Unsubscribe!
Rich
Old Feb 13, 2012 | 05:23 PM
Slee256's Avatar
Originally Posted by sstevojr
It needs the fob to work (the chip enables the car to start)
Are you saying that if the battery goes dead in the electronic key, that you couldn't start the car using the manual key? I don't thing that's right, but I'm no expert. What would be the point of even having an emergency manual key in that case, other than to unlock the doors and get in the car. You'd be able to get in the car, and then you'd just have to sit there with a car that won't move, which I can't imagine that's the case I've been getting a "low key battery" warning on my dashboard, and I thought about putting in a fresh battery, but then I figured that even if it goes dead I could use the manual key to open the doors and start the car. If that's not true, then I guess I better get out to Radio Shack and buy a new battery ASAP before I get stranded in a blizzard or frigid weather...
Old Feb 13, 2012 | 05:36 PM
sstevojr's Avatar
The key is for when the battery dies, but you still need the computer chip to unlock the ignition system.
At least I'm pretty sure. Don't we need to flip the key around (with the back part now in the fob) in order to work? Hmmm, maybe I should try a little experiment.
Old Feb 13, 2012 | 05:58 PM
jkennedy293's Avatar
You are correct. The manual goes through this in great detail. The car sends enough current through the key to power the fob so the car can start.
Old Feb 13, 2012 | 07:13 PM
sstevojr's Avatar
Yahtzee!!
Old Feb 13, 2012 | 07:47 PM
Slee256's Avatar
Sooo, the bottom line then is that I don't need to worry about not being able to start the car with the manual key if the battery on my electronic key goes dead, correct???
Old Feb 14, 2012 | 04:31 AM
Correct.
shane_evo7
Jan 11, 2017 06:53 PM
gizmotoy
Sep 17, 2015 12:12 PM
JeffMas1587
Jan 5, 2008 03:37 PM
