Windows will not work
Old Mar 28, 2012 | 10:21 AM
DjRags604's Avatar
So I went to McDonalds yesterday and pull up to the drivethrough speaker. I went to roll down my window but it did not work. Checked to see if I had the lock on, still nothing. Tried the other windows and still nothing. I'm guessing it is a fuse that needs replacing. I don't have an owners manual for the car though so can anyone point me in the direction to go (ie. starting with where is the fuse box). Thank you for any help.
Old Mar 28, 2012 | 11:04 AM
jkennedy293's Avatar
The fuse box is nelow your left knee, on the dash. I believe it has a map of the fuses on the inside cover.
Old Mar 31, 2012 | 03:18 PM
DjRags604's Avatar
Thanks for that. The diagram is hard to read but there is nothing that resembles windows that I can see. Anyone with ideas?
Old Apr 2, 2012 | 04:55 PM
neogeo64's Avatar
http://www.roadraceengineering.com/r...20Diagrams.pdf
Section (90-24) through (90-26) show it's fuse #20 (pink)?
Section (90-188) shows the full wiring diagrams for the door locks.
Old Apr 4, 2012 | 02:33 PM
DjRags604's Avatar
Thank you very much. Unfortunately every fuse tested works so its to the dealership I go. Car is still under warranty so I'm ok on that front unless they some how deduce that the sub I had installed at Best Buy is causing the issue.
04Ralliart96
Feb 22, 2016 09:54 PM
whotippedmycow
Dec 20, 2013 02:53 PM
Joho22
May 29, 2012 06:25 PM
BrianDz
Lancer Troubleshooting
May 28, 2011 04:22 PM
ru4real
Jan 6, 2010 09:19 AM
