rpm fluctuation
Old Jun 16, 2012 | 04:46 PM
petro's Avatar
rpm fluctuation
sorry if this has been discuseed (I looked but couldn't see anything).
Anyways, when I take my foot off the throttle I have noticed (in every gear) that there is a subtle and small increase in rpm before it starts to decrease. Like I said, it is very subtle and the increase is small.
Just wondering if it is normal and/or what it could be? The car has 9,000 km on it.
Thanks.
Old Jun 17, 2012 | 03:08 PM
ande1234's Avatar
It should also do it when you down shift in auto or manual it makes the ride smoother
Old Jun 17, 2012 | 03:21 PM
petro's Avatar
Thanks. It seems dependent on the Cobb tune I am running. On a separate note, I just checked my boost for the first time and it is at 17.6 at WOT. I can't wait to add a couple mods and get professionally tuned in a couple weeks...sigh
Old Jun 17, 2012 | 03:33 PM
sstevojr's Avatar
It's most likely caused by the fuel map, when you lift the engine goes rich. This will cause a slight increase in combustion for just a moment. Then it starts to cut fuel.
Old Jun 17, 2012 | 03:39 PM
petro's Avatar
Thank you. As I sated earlier, I'm at about 17.6 psi at WOT. I'm adding an ams bov and 3 port solenoid. What should I be expecting for psi following a professional tune? Just curious and I know you know your stuff aha.
Old Jun 17, 2012 | 04:04 PM
sstevojr's Avatar
What ever you tuner chooses, most commonly 22psi.
