Stalled trying to reverse
Old Jul 12, 2012 | 08:23 PM
mxzas's Avatar
Today I turned the car on, put it in D to go forward, turned my steering wheel all the way left, then put it into R to back out, the R was flashing and my car stalled on the spot, this is the first time it ever happened to me, since then it has not happened.
Has anyone ever stalled their car going to D to R before? I know the R flashing is a common occurance but I have never seen an automatic car stall before.
My car has the upgraded fuel relays from SSP, the black ones to be exact, mods are listed in my signature.
My SST has been solid, no problems with my engine either.
Could it be that when it was trying to catch reverse and it stalled? I was not on an incline either.
Thanks for your input.
Old Jul 19, 2012 | 05:05 PM
BLee's Avatar
happened with my 2012 once when it was really cold out. i didnt worry about it to much.
Old Jul 20, 2012 | 07:16 AM
gaabbee's Avatar
could be the extra load on the motor from the power steering when you turned all the way and the sst or ecu not giving enough rpms for the motor to continue running once reverse was engaged.
Old Jul 20, 2012 | 09:43 AM
mxzas's Avatar
Thanks! That makes a lot of sense.
Old Jul 21, 2012 | 12:30 PM
sstevojr's Avatar
Mine "trys" to stall all the time when going from R to D (the opposite of you). I know what the problem is, but the "easy" fix is to lightly tap the throttle the second I've shifted.
Old Jul 21, 2012 | 12:40 PM
RoMeIX's Avatar
I was in a friends car and it did thus once as well. I think it does have something to do with the power steering because his wheel was all the way over as it happened.
Old Jul 21, 2012 | 06:23 PM
nunyas's Avatar
my car is like sstevojr's. It doesn't and hasn't ever (**knocks on wood**) stalled, but the RPMs do regularly drop to about 500 or so when i go from R to D, normally when the car is still warming up.
Old Jul 21, 2012 | 07:48 PM
richardjh's Avatar
Ditto.
Rich
mdosu
Aug 27, 2014 08:32 PM
mike594x
Jun 15, 2014 12:24 AM
jwick76
Lancer Engine Management / Tuning Forums
Dec 12, 2012 09:54 AM
Nelson999
Jun 19, 2012 08:28 AM
nawtyboy03
Lancer Tranny/Drivetrain Tech
Jun 27, 2007 02:32 AM
