Transmission fluid
Transmission fluid
I'd search the forums for this question, because no doubt it's already been answered, but Im on my phone and its already agitating typing so bear with me. Looking to change my transmission fluid and would like to know which brand I should use considering the stock transmission fluid blows. Any input would be marvelous.
If you actually are driving an 09 Ralliart then you have the Twin Clutch SST. Which would be more than likely destroyed by Redline mt90 or amsoil.. you need a dual clutch fluid, such as diaquenn, or the alternative Pentosin FFL2 (i use this). There is tons of threads already on this. Search "sst fluids" or something of that sort and see
I'm looking myself, the cheapest option I can find is:
Revenol 1L @ 13.95 ea w/free shipping.
Second cheapest is Pentosin FFL-2 @ 17.95 1L
Then there is stock Diaqueen SSTF-1 at almost double the price.
Revenol and Pentosin are discussed in the "All about SST Fluid" Thread
I used pentosin FFL-2 oil for my transmission which Mitsu tested in my car and it passed their oil test.
Filter:
http://www.fredbeansparts.com/mitsub...on-filter.html
Diaqueen SSTF-1 Transmission Fluid (if you decide to buy the OEM fluid, you have to order two since they come in 4L containers):
http://www.fredbeansparts.com/mitsub...tion-x-mr.html
Buy the one from SSP. Its $70. http://www.sspperformance.com/produc...nt-sst-filter/
They have a reusable stainless steel one too.
---Ralliart Fluids---
Fuel: 14.5 gal (55.0L) 93 Octane
Engine Oil: Oil pan- 5.1 qt (4.8L) 5W-30
Filter- .32 qt ( 0.3L)
Power Steering: (As required) Genuine Mitsubishi Power Steering Fluid
TC-SST: 8.0 qt (7.6L) DiaQueen SSTF-I
Transfer Oil: .85 qt (0.8L) DiaQueen LSD Gear Oil
AWC Control Fluid: .95 pt (0.9L) Diamond ATF SP III
Rear Differential Oil: .58 qt (0.55L) DiaQueen LSD Gear Oil
Brake/Clutch: (As required) DOT3 or DOT4
Hood Lock Release mechanism and safety catch: (As required) Multipurpose Type
Grease NLGI Grade 2
Engine Coolant: 7.9 qt (7.5L) Long Life Antifreeze Coolant or equivalent
Washer Fluid: 4.3 qt (4.0L) Whatever you choose!
Refridgerant (Air Conditioning): Label under hood upper left corner. HFC-134a
Found this on the forum. Hopefully it helps
Grease NLGI Grade 2
