question regarding ACD modes
Old Aug 26, 2013 | 06:36 AM
Ltong's Avatar
Hi, guys, i have a question, ralliart has 2 acd settings, normal and sport, plus SST has manual mode, my question is:
are there any difference between:
1. manual + normal
2. manual + sport
because since you are using manual to control shift, acd doesn't do shift for you, but are there anything else different?
Old Aug 26, 2013 | 08:16 AM
nunyas's Avatar
sport mode shifts "harder" (slips the clutches less for a faster firmer shift), normal mode shifts smoother (slips the clutches for a smoother more comfortable shift).
Old Aug 26, 2013 | 09:16 AM
Raptord's Avatar
FYI, you're getting mixed up between ACD and SST. The ACD has nothing to do with shifting.
Old Aug 26, 2013 | 07:06 PM
nunyas's Avatar
this is true. ACD has 3 settings tarmac (asphalt), gravel, and snow...
Old Aug 27, 2013 | 05:55 AM
Ltong's Avatar
damn.... my bad, i got confused.... thx for clear that up.
speaking of .... read ACD stuff, if you accidentally switched setting to gravel or snow without notice and drive on the tarmac for long time, will that cause any harm?
Old Aug 27, 2013 | 06:06 AM
Raptord's Avatar
No, none of the settings will cause harm if you use them on the "wrong" surface. They are only to optimize the diff's locking for that surface type.
IC_EVO
Mitsubishi TC-SST Discussion
21
Dec 30, 2016 08:55 PM
zorca
22
May 4, 2014 03:04 AM
Ray Knight
Jun 27, 2013 09:51 AM
Magnus82
31
Aug 20, 2010 11:19 AM
akj237
Dec 16, 2009 12:37 PM
