No Heat Coming Out of Vents?
Old Sep 17, 2013, 07:28 AM
Bom's Evo's Avatar
Hello,
Just noticed no heat coming out of my vents. Air comes out at full power, but its cold air. A/C works perfectly and the fan comes on. When I change the temperature it stays cold.
I just topped off the coolant and made sure no air bubbles in the system this morning. Still no good. I just read about the Heater Control Transistor and the Blower Motor might need replacing.
Question is since it blows air, do I just change the heater control transistor "blower resistor" or do I have to change both?
Thanks for the help.
Old Sep 17, 2013, 10:42 AM
Veronica's Avatar
No. This indicates that the flapper door on the air box is not moving. Try the heat control transistor first.
The blower motor works - it blows air 'at full power', eh?
Old Sep 17, 2013, 01:42 PM
stfuad's Avatar
heater core could be plugged as well
Old Sep 18, 2013, 06:08 AM
Veronica's Avatar
^not as likely. The heat would have been a gradual less and less over time...
Quick check is to feel the heater hoses going in/coming out of the firewall. Are both 'hot'?
These cars are low mileage and unless OP put 'stop leak' in radiator....
Old Sep 19, 2013, 09:30 PM
Bom's Evo's Avatar
Just waiting for the new heat controller transistor now I ordered it for 50 bucks.
I don't use stop leak cause no leak just Prestone 50/50 after my evo x swap.
Old Sep 20, 2013, 08:44 AM
Veronica's Avatar
I think you found the bad part. Please consider doing a write-up on remove/replace.
Old Sep 22, 2013, 06:26 AM
Bom's Evo's Avatar
I installed the new Heater Control Transistor.
This was not the issue. The new transistor, my fan would not even turn on at all AC/Heat.
I switched back to the old transistor and that got my AC and Fan working again. However, I still have no heat. Checked all the fuses and already did the coolant and thats all good.
Looks like the fan needs to be replaced since I read that theres also a fuse within that......
LeXcite
Jan 17, 2022 08:05 PM
llDemonll
Sep 22, 2021 05:43 PM
Evo_Goodness
Nov 29, 2016 05:47 AM
josephatgts
Lancer Troubleshooting
Sep 18, 2016 02:23 PM
Quick Reply: No Heat Coming Out of Vents?
