A crazy noise this morning
That noise definitely happens when your cooling fan kicks on. Start from there. Check (while the car is off) to make sure that the blades aren't loose and check all the hoses and wires around the area to make sure nothing can be vibrating or rubbing near the cooling fan blades or motor.
I'd like to say probably, maybe. A compressor clutch isn't a normal wear item, so maybe.
process of elimination is the only way you're gonna figure it out.
You think it's the a/c compressor clutch?
Now that it's noisy again, does it make the noise every time you start it?
Try taking the belt off, and start it.
Does it still make noise?
If it doesn't when you spin the A/C pulley does it feel rough?
Is it the A/C Condenser Fan?
Disconnect the plug and jump battery power to a pin and ground the other.
Does it make noise?
Does it make noise?
