Urgent!! Need help!
Old May 11, 2014 | 06:58 PM
apexbeast's Avatar
Urgent!! Need help!
So I was changing my SST fluid and I stripped one of the plugs it goes in completely but it turns forever basically even tho it sits flush. Am I screwed? I took it out and the thread is damaged so Idk what to do :/
Old May 11, 2014 | 07:34 PM
Napalm_Enema's Avatar
I'd get a new plug if it were me, why risk it?
Old May 11, 2014 | 07:38 PM
apexbeast's Avatar
Can I just get a new drain plug that self taps like the ones that they sell st AutoZone for oil pans? Just want to make sure it's sufficient for the sst in our cars or if somehow it will screw it up. Since the thread on the actual tranny is screwed I have to make a new thread somehow
Old May 11, 2014 | 07:39 PM
apexbeast's Avatar
Just noticed in my post I made it seem like the plug itself was messed up but it's actually the thread on the tranny :/
Old May 11, 2014 | 08:22 PM
ikt's Avatar
ikt
well all it really has to do, for now, is keep the oil in, so if a self tapper does that, should work
Old May 11, 2014 | 08:25 PM
Gqracer's Avatar
You have to retap it to fit a bigger drain bolt. Good luck.
Old May 11, 2014 | 10:18 PM
apexbeast's Avatar
Does anyone know by any chance what size helicoil I would have to buy? I have no idea :/
Old May 12, 2014 | 02:26 PM
ikt's Avatar
ikt
a self tapper doesn't need a helicoil...
is it just the drain pan? You will want to replace the whole thing eventually.
Old May 12, 2014 | 06:52 PM
apexbeast's Avatar
So I bought the tap and drill bit I need to make a larger hole.. however I noticed that there isn't much space around to make the hole larger and there is a component of the transmission right above the hole. There is no way I can thrill through the hole thread and not hit it. So I bought figured I can use an oil drain plug sealant around the bolt to make sure it doesn't leak and it should be ok? I don't want to mess it up more than it is and since its only a few threads that are messed up I think the sealant should be sufficient. The bolt screws all the way in, the only problem is it keeps spininning slowly
Old May 12, 2014 | 08:22 PM
apexbeast's Avatar
using this on threads
Old May 13, 2014 | 09:00 AM
Veronica's Avatar
OR in the 'Help[tm]' section of the autoparts store there is a rubber 'plug' for oil pan bolts that are stripped. Try it. If it works (and it should).... would be waaaay easier
Old May 13, 2014 | 09:01 AM
Veronica's Avatar
I assume you pulled the bolt and it's threads are fine (so that the case is stripped)...
sworddemon
May 15, 2014 06:25 AM
JukEboXAuDiO
Site Feedback / Suggestions
Apr 29, 2014 12:02 PM
slowsrt4:(
Southeast Region
25
Apr 8, 2014 05:20 AM
Thahomeboyb
02-03 Lancer Show / Shine
13
Mar 30, 2014 09:07 PM
carlosevo
Feb 10, 2014 09:24 PM
