Reverse stall - RPM dip
Old Jun 8, 2014 | 07:42 AM
mike594x's Avatar
Sometimes when I put the car into 'reverse' it acts like it wants to stall. It hasn't stalled yet, but the RPMs dip like crazy, usually going down to like 300~. This A) only happens AFTER the car has warmed up and is operating at its normal 700~ RPM idle. and B) it only wants to stall if I dont give it gas. As soon as I give it a little gas or a rev it seems ok... It's just weird. Has anyone else dealt with this or heard of this? I know my tranny fluid and diff fluids are overdue for a flush/fill. Car has 46K on it and I don't believe either of those fluids were ever changed. (I bought the car used.) I will be doing that in the next couple weeks. But again, just wondering if this has happened to anyone else, or if this is a common occurrence with this cars at certain points in their lifespan. Thanks guys.
Old Jun 8, 2014 | 07:54 AM
mike594x's Avatar
To be more accurate in explaining and helping you guys understand: This all happens on level ground, no inclines. There doesn't feel like there is any resistance or something like that. I never notice any smoke or smell of any kind. Its just so weird. RPMs dip way down and it almost stalls, but doesn't.
Old Jun 8, 2014 | 08:36 AM
TrailBrake's Avatar
Were you able to scan and check for any codes when the RPMs wobbled?
I had a somewhat similar issue with my first RA, which ended up being related to the throttle body/throttle position switch (as they are both one unit on our cars and can not be replaced separately).
Old Jun 8, 2014 | 08:39 AM
mike594x's Avatar
No codes or check engine lights. Did a visual hose connection check, everything is tight and seems fine. Car acts and drives normally, besides this one thing with reverse, which doesn't happen constantly, just every-so-often.
Old Jun 14, 2014 | 11:27 AM
mike594x's Avatar
BUMP **
No one has ever had an issue like this or similar, or has ever heard of it? I'm hoping it goes away when I do my tranny fluid change. 47K on the original fluid, so I'm sure the filter is gummed up and the fluid is worn out.
Old Jun 15, 2014 | 12:24 AM
Mia_RA's Avatar
Mine has done it since I bought, but only on very hot days. It only happens after the car has been fully warmed up then sat for a little bit then I try to drive off again. I always figured it was all the heat since these cars tend to heat up, especially in hot weather.
2slowEVO8
Sep 19, 2021 02:14 PM
giumela
Sep 5, 2014 09:54 PM
elementsk8erq
Mar 19, 2009 01:53 PM
bloody_angel1
Lancer Troubleshooting
Jul 20, 2007 06:04 PM
