Worrying new noise
So as of this past Saturday my motor started making a new noise that sounded like knocking at first ( no not the transmission i know what that noise is) got to work and called one of the guys i work with over to see if he recognized the sound said it sounded like one of my valves, valve springs getting stuck. (putting it out there hes a master tech at nissan and has alot of experience 25 years or so) so we flushed my motor cleaned my pcv valve to make sure it wasnt that producing the noise too and it stopped for two days. Well today got to work and just got off for lunch started my car went back inside came back out after it had warmed up and its making the noise again and to top it off my injectors are being more loud than normal, which for our cars are already noisy. Does anyone have any idea what this might be? bad pcv valve just being loud? Valve springs needing adjustments? Im at 32,000 miles cobb ebcs, borla catback stage two tune access port tune on 91 fuel. im going to try and upload a video here in a second.
I can never hear problems in these videos lmao
Umm unplug injectors one by one seeing if the "odd" noise stops. I doubt it's the injectors...
Where is the sound coming from in the engine bay? Does the sound stop when driving? Could you put the car into drive with the e brake on and the sound stops?
noise doesnt stop when in gear and its not my injectors i know that. its almost like the sst noise but less frequent and higher pitched. i pulled my spark plugs yesterday and ran a compression test and all was good with those. im about ready to pull my valve cover and see if anything is loose up there. id measure it all but i dont have a micrometer or anything for fine measurements.
hEAD DOWN TO HARBOR FREIGHT AND PICK UP A CALIPER AND MICROMETER FOR 50 BUCKS TOTAL....THEY ARENT THE GREATEST QUALITY AT ALL BUT THEY WILL GET THE JOB DONE WHICH IS WHAT YOU NEED NOW.
PS pardon my caps, I use caps lock alot at work and forget about it.
LovingLancer
Lancer Troubleshooting
Aug 20, 2013 12:49 PM
icantdrive75
May 18, 2011 04:47 AM
iyi0521
Jan 16, 2007 03:26 PM
be12nard
Apr 24, 2005 07:06 AM
thereasonsf3
Lancer Aftermarket Forced Induction Tech
34
Dec 20, 2004 12:49 AM
