Can you tell what is making this noise?
Old Jul 17, 2016 | 05:27 PM
drivejumpfly's Avatar
I noticed this within the last week and have some ideas of what it could be, but I am not sure what it is. You probably will need to turn the volume up pretty loud on your computer to hear it. Listen when I turn the wheel mainly to the left and then I slowly back out of turning to make the sound again. The sound is similar to a spring compressing and decompressing, at least that is the best I can come up with to mimic the sound.
It happens when I am steering left. I did the same thing in the other direction and it did not make that sound 98% of the time.
Some ideas I thought were a bearing or a cv joint but I figured I would bounce it off you guys before I start taking stuff apart.
60K+ miles are on the car
Old Jul 19, 2016 | 09:08 AM
Veronica's Avatar
1. Could be the front CV joint (jack with jack stands) and pull/push on the wheel for "play". Grab the CV shaft and check for play.
2. Could be the strut upper mount.
Any competent tire/alignment shop should be able to check it out for you if you can't find a failed component.
Old Aug 17, 2016 | 10:18 PM
It was the CV joint. I will update this thread after it is completely fixed.
Old Aug 18, 2016 | 09:30 AM
Veronica's Avatar
I am surprised and disappointed that CV failed after only 60K miles...
leemaster
May 22, 2015 12:07 AM
RevLimiter
Aug 20, 2012 07:01 PM
evo racing
Sep 12, 2005 03:19 PM
Grod101
Apr 17, 2004 03:00 PM
