AYC DTC C0420? - Need help find out this DTC
Old Mar 31, 2017 | 04:48 PM
wluc12's Avatar
Hello,
I have had my ABS/TCC not working(off) for a year or so, and I have finally gotten around to fixing it. I found out the my AYC was throwing the code for the right-rear wheel speed sensor (using evoscan). I replaced this sensor today, and now its throwing the code C0420. The ABS/TCC will work until about third gear if I clear the code, and randomly on it owns when I first start up the car. I had this same erratic working and non-working ABS/TCC before I switched out the sensor, though. I can not find any information on this new code that is appearing. I have heard of P0420, but it is absolutely C0420 (unless I am crazy). I have included a pic of what I am seeing in evoscan.
I would appreciate any and all help on finding out what DTC C0420 is.
I just payed off my car and I have so much other maintenance I want to get done, so it can last another 6 years.
Evoscan Displaying AYC DTC C0420
Old Apr 1, 2017 | 03:24 PM
dan-lincs's Avatar
https://www.engine-codes.com/p0420_mitsubishi.html
P0420 MITSUBISHI - Catalyst System Efficiency Below Threshold Bank 1
Running a decat / testpipe?
Old Apr 1, 2017 | 06:42 PM
wluc12's Avatar
So I re-flashed my ecu with the same GST Basemap I had before and cleared the DTC's using ecuflash. I took the car for a spin and the ABS/ASC failed again, but this time different codes showed up. I looked them up and this is what I found.
C1044- Abnormality in periodical signal for RR wheel speed sensor
(so maybe the new wheel speed sensor is working, but now there is another issue)
c1290- temporary CAN timeout
(below are the probable causes I found for this code)
PROBABLE CAUSES----
Engine ECU malfunction
4WD-ECU malfunction
Steering wheel sensor malfunction
Malfunction of the CAN bus
ASC-ECU malfunction
Malfunction of ETACS-ECU
u0141- ETACS-ECU CAN communication time-out
(my A/C stopped blowing cold a month ago, maybe this is why)
PROBABLE CAUSES---
Damaged harness wires and connectors
Malfunction of the A/C-ECU
So is my ecu malfunctioning?
Should I get a new one?
My car runs perfectly fine, except for the A/C not blowing cold, and ABS/ASC issue.
Thanks for any input!
wluc12's Avatar
Well, either connection to the ecu,asc-ecu,or ac-ecu or the actual ecu's themselves are malfunctioning. Since I think I'm as far as I can take this, I am reverting to stock and taking it to the dealer. Hopefully, they can give me an accurate diagnosis, and I will be able to replace one or two of these parts, myself. The worst case scenario seems to be that a cable or two have gone bad in the car. That would suck; I'd rather replace a part then run electrical cables, and connectors.
(I don't know if we have an asc-ecu or asd-ecu or both)
Old Apr 1, 2017 | 06:46 PM
wluc12's Avatar
Nah, I dont have any exhaust mods. Just the boost pill, it was C0420 and definetly not P0420. I re-flashed my gst basemap, drove around, and got 3 new codes. These codes seem to more accurately describe what might be going on.
PROBABLE CAUSES----
4WD-ECU malfunction
ASC-ECU malfunction
PROBABLE CAUSES---
Old Apr 2, 2017 | 02:21 AM
dan-lincs's Avatar
Edited
Old Apr 2, 2017 | 11:22 AM
dan-lincs's Avatar
Edited.
Tachyonzero
Feb 27, 2020 03:21 PM
wluc12
Apr 1, 2017 06:40 PM
blowngasket
Jan 22, 2016 09:23 AM
cuscoevo
Aug 2, 2013 09:53 AM
Blacksheepdj
Lancer Troubleshooting
Feb 23, 2008 01:29 PM
