Heat Shield Rattle?
Heat Shield Rattle?
New owner ( about 4 months in ) and I've noticed a few things... Anyone else? Or am I nuttier than squirrel turds.
1. There is a heat shield that has been rattling the last few weeks... Think I have narrowed it down to the one over the exhaust manifold on the top of the back side of the engine... Can anyone confirm if you've had this happen before? Bolts are tight and it slides around... again is that normal or is something worn ( was going to fix with 2 stainless washers or a couple of high temp rubber washers )
2. Splash Shield. Damn this thing and driving in snow... Front one is hanging low... Is there a better aftermarket alternative?
3. Living in Maine I have noticed that even on plastic parts, there are tiny orange rust spots appearing on the paint... It is not rusting through or anything on the metal parts, if anything it's more prevalent on the plastic parts. I can rub them out easy enough and just figured it was something in the paint reacting with the salt from the roads, anyone else have this issue?
4. These things are BEASTS IN THE SNOW!
5. Anyone done any plasti dip on their cars that have some pictures? I have an all white Lancer Ralliart SportBack... Wanted to do the lower front lip in black, side skirts in black, and front hood scoop in black.
1. If it that heat shield gettign teh bolts out will be problematic, they are straight into the manifold. I had the most success by letting the car warm up and then attacking the bolts, then half way through warmed the car up some more.
2. There is an aluminum for the Evo X that will fit our cars.
4. #truth
5. Check the exterior part of the forum, this has been cover ad nauseum
4. #truth
1. I had good luck by just bending that heat shield so it stopped rattling. Try that first.
2. There are Ralliart-specifc undertrays that are metal.
3. ?
4. Yeah!
5. There are plenty of pix in the forum. My car is black - so no help. SRY.
3. ?
4. Yeah!
kuya7888
Mar 18, 2015 05:57 AM
Rob_GPT
63
Apr 6, 2011 09:21 PM
evo8tp
Oct 19, 2010 07:59 PM
