Tire on this wheel..will work out?
Hey I just found some wheels for my RA...can you tell me if it would fit.. I searched it up on tireracks.com; I enter in the 2009 RALLIART. So I'm sure it would fit but would it fit w/ the stock tires I have on? Tell me what you think ? I'm looking at the Enkei EDR9..
Theres two type...which should I get:
* The first one is 18x7.5
Offset: +45mm Backspacing: 5.98" Bolt Pattern: 5-114
Rec. Tire Size: 215/45-18
Weight: 22.8lbs.
View Important TPMS Info
* And heres the 2nd 18x7.5
Offset: 38mm Backspacing: 5.74" Bolt Pattern: 5-114
Weight: 23.0lbs.
Can someone tell me which I should get?; Or which would fit w/ my stock tires? Or recromendation?
Weight: 22.8lbs.
Weight: 23.0lbs.
Read through this thread:
https://www.evolutionm.net/forums/09...s-fitment.html
If you can't find the answer to your questions in that thread, you should pose your questions in that thread. That way, the forum isn't filled with redundant posts, and others can benefit from the information too. Good luck.
bakuro117
19
Feb 7, 2013 07:14 AM
mar387
29
Aug 31, 2011 10:19 PM
kaiwang
For Sale - Wheels / Tires
Aug 6, 2009 07:51 AM
Neal@tirerack
May 25, 2006 10:21 AM
