Coil overs installed
Old Sep 8, 2009 | 11:08 AM
  #31
justin81's Avatar
Originally Posted by evil03
sweet!~!!!!! i am soo temped to just hit..... but that about a G... damn wheels or coilovers??? thats the big question
coilovers!!!! I wish I had $1k laying around. I spent all my money on a new camera
time to start saving or looking for things around the house to sell.
Old Sep 8, 2009 | 11:36 AM
  #32
perryrace's Avatar
Pictures
OK per multiple requests here are some pics of the car as she sits.
So now the tuning is done - TTP engineering (Nice folks, great service and a big improvement in drivability and power levels)
Carbotech brake pads installed (Amazing what just a better brake pad can do)
Coilovers completed (Again great service, perfect fit for all brackets lines etc and easy to setup with good range of adjustability)
Wheels and tires here need to install (18x7.5 Enkei Performance EKM3) with an agressive track tire !!
Ready for the track !
Mark
Attached Thumbnails Coil overs installed-sa1.jpg   Coil overs installed-sa2.jpg
Old Sep 8, 2009 | 11:42 AM
  #33
DarksideEng's Avatar
You always get suspension before you get wheels! Its the way the world turns
Originally Posted by perryrace
DarksideEng- Sure have at it. Happy to send you the higher quality images if you prefer I had to cut these down to post here.
Mark
Yes, please do. Contact@DarksideEngineering.com
Originally Posted by EngRWW33
how much camber adjustment did these give you? F + R...
Depends on how low your car is, but they will give you over 3 degrees per corner if you want it.
Old Sep 8, 2009 | 11:45 AM
  #34
perryrace's Avatar
EngRWW33 - Fronts have a large adjustment range, I did not look at positive camber but can dial in in excess of 3.5 degrees negative (I know this as I had to pull out some camber to hit my desired setting). I have started at -2.2 and will go from there. I am certain the camber range is now in excess of 4 degrees. I just aimed at what I was looking for an initial track setup so did not measure through the full range.
The rears do not have pillow ***** so you are stuck with the stock adjustability. Lowering the car did help. I am now showing an indicated negative camber of almost 1 degree. I have a few ideas on how to improve this and am working on a rear camber adjustment capability. If it is needed and if it works I will post here. Will know more with additional track time.
Old Sep 8, 2009 | 06:19 PM
  #35
Zereul's Avatar
Three Q's!
1) so the coilovers for the ralliart and the base lancers are the same?
2) is there a part number for these?
3) ship to Aust???
Old Sep 8, 2009 | 07:57 PM
  #36
perryrace's Avatar
Zereul - Did you try sending darksideEng a PM and or an email as listed above? They have been very respponsive for me. I do not know how often they check this forum. Good luck with your project. Hope all is going well down under !
Old Sep 8, 2009 | 09:42 PM
  #37
TTP Engineering's Avatar
Mark
Thanks for your kind words Mark.
Let us know if we can be of further assistance.
Thanks
TTP
Old Sep 8, 2009 | 11:45 PM
  #38
gaspipedreamer's Avatar
whoa its my cars twin, gas cover and everything might be same tint ahaha cept i got lowering springs and u got coil overs which i cant quite afford at the momment, but later for sure!
Mark
Old Sep 8, 2009 | 11:57 PM
  #39
evil03's Avatar
Mark
thats pretty low... how much did you drop the front and rear??
Old Sep 9, 2009 | 04:15 AM
  #40
perryrace's Avatar
Approx -1.5" rear and -2" front.
Old Sep 9, 2009 | 04:55 AM
  #41
EngRWW33's Avatar
Thanks for the info.
Old Sep 9, 2009 | 06:14 AM
  #42
08Lancer89's Avatar
pm me a price i want
Old Sep 9, 2009 | 06:19 AM
  #43
suprPHREAK's Avatar
So whats the verdict? Do they have noticeably improved handling/responsiveness over stock?
Can't wait to hear!
Old Sep 9, 2009 | 03:11 PM
  #44
evil03's Avatar
i smell GB??
Old Sep 9, 2009 | 08:14 PM
  #45
perryrace's Avatar
suprPHREAK - I will be on track this weekend and hope to do some additional tuning. I will then be happy to post setup and handling info. I just do not have enough data at this time to post a qualified opnion.
evil03 - GB??
Mark
