Corner Weights - Suspension setup
After installing the BC coilovers I have setup the suspension to the following:
Front Caber -2.2 degrees
Rear Camber -1.2 degrees
Rear to front rake -3/8”
Corner weights to 50% with a total car weight of 3377lbs (Drives weight not included but was added for corner weight measurements)
The BC coilovers allowed me to set the ride height at the desired camber. I then scaled the car and made small ride height adjustments until the car was within 1% cross weight. I then adjusted the spring tension to get to exactly 50% cross weight. Total time was less than 2 hours.
The car has significantly more front end grip. Is compliant and behaves much better under braking.
I still have the ability to dial in more camber and or rake if needed.
The caster numbers are not finalized yet. Long story short I have ordered a better rim clamp for my caster camber guage (also called dunlop clamp) I can not get an acurate reading at this time. More to come on this one. When I did the initial alignment (on a pro rack) I was showing in the 2.2 range but again is not the final setting.
Mark
Mark
AWD Motorsports
Evo 'For Sale' Suspension / Brakes / Handling
59
Aug 12, 2015 09:58 AM
robnval
17
Dec 2, 2014 01:31 PM
PRS
52
Jan 4, 2013 07:29 AM
