235 on 7.5" wheel
235 on 7.5" wheel
Can you run a 235 tire on a 7.5" wheel or is it overkill? I know most tire manufacturers recommend to run a 225 on a 7.5" wheel. Stupid question I know just curious. Don't want to gay up my car.
Planning to get new tires onto stock rims as well
That's what I thought. From everything I read the max I should run on a 7.5" wheel is a 225. I should have gotten the 8" wheels. Maybe I can sucker my better half into running the 7.5" on her Ralliart since she considers that the family car and I can get 8" for mine. Although 225's on my wheels with a better compound tire should suffice. I thought 235's would be pushing it and I don't want to negate performance for looks.
Yes a 235 will fit on a 7.5" wheel, its probably not the best setup though. I would go max 225 and I'd even consider staying with a 215. The difference in grip between a 225 and a 215 isn't going to be very noticeable as long as you buy a quality tire. The best tire and wheel setup I've personally felt is a 225 tire (RE01R) on an 8" wheel. It was flat, it turned in great, it had plenty of grip and it communicated nicely. After that I ran a 245 on the same wheel and while the ultimate grip level was higher, the steering felt more vague.
DsmEvo87
20
Aug 18, 2015 08:14 AM
Carloverx
10
Oct 30, 2006 04:14 PM
GTVEVO
12
Apr 1, 2004 11:32 AM
