Probably a dumb question
Old Jul 22, 2011 | 07:11 AM
Immaculate's Avatar
The left rear of my car is sitting lower than the right. When you look at it from behind it sits lower on the left side. When you look at it from the front it looks even. Could this be a spring or a strut? Or something else?
I just noticed it and I think its been like that since I've had the car so its bugging the crap out of me. Again, sorry for the dumb question and thanks for any response!
Old Jul 22, 2011 | 08:35 AM
aaronk's Avatar
If its stock suspension take it in and get the dealer to look at it.
Old Jul 22, 2011 | 08:41 AM
Immaculate's Avatar
Thats the thing I live 3 hours away from the nearest Mitsu dealer. Was just hoping for some suggestions on what it could be. There isn't any clunking or out of the ordinary noises. It still drives straight and everything.
It is the stock suspension.
I'm going to be installing Eibachs here soon so if that fixes the problem then I wouldn't need to bring it in. I guess I'm more concerned if it is a strut.
Old Jul 22, 2011 | 08:49 AM
Jdunn502's Avatar
should probally get it checked out before upgrading it
Old Jul 22, 2011 | 10:12 AM
Mad_SB's Avatar
you sure your on level ground? if not it very easily could look off, measure from the wheel centers to the fender lip on both rears, move the car and do it again, then post the measurements.
unless you have a shock body / mount failure the shock will not affect the ride height.
Old Jul 22, 2011 | 10:28 AM
Immaculate's Avatar
Yeah, everytime I park somewhere I have checked to see if its the same when I get back to the car for the past two days.
I will measure them, I suppose that is the easiest way to tell.
Are their any other reasons for this to happen?
Old Jul 22, 2011 | 10:44 AM
Mad_SB's Avatar
bent spring perch, failed shock mount, failed unibody where the shock mounts... I would think you would be hearing a whole lot of noise if any one of those were the case.
Old Jul 22, 2011 | 01:36 PM
Immaculate's Avatar
I just measured and its roughly a half inch lower on the left side
Old Jul 25, 2011 | 06:44 AM
Immaculate's Avatar
It is soooo confusing...
05evoblack
Feb 27, 2014 08:17 AM
drocksmash
Northwest Region
16
Jan 19, 2011 09:04 AM
shutout809
Oct 1, 2009 09:32 AM
RoBear
Jan 16, 2007 08:08 AM
DfWeVo
Jul 1, 2004 01:29 PM
