What to replace brakes with?
Old Nov 8, 2011 | 08:20 AM
xi's Avatar
xi
I'm at 41k miles on the original pads.
Front brakes @ 0.16 (4mm)
Rears @ 0.2 (5mm)
Front rotor has like, .02 wear (.5mm) so I think they're fine.
Replace pads or wait? If I gotta, I wanna do it now before the winter cause it's a PITA in a snowy drive way.
Also, anyone tried the duralast cmax ceramic pads from autozone? They're a pretty good price and seem decent for DD. Can anyone confirm if I punch in 09 lancer GTS, they pads'll fit the RA?
Thanks!!
Old Nov 8, 2011 | 12:34 PM
stfuad's Avatar
Anything under 3/16" is worth replacing. I have Wagner ceramic pads on my car and they do alright for DD.
Old Nov 8, 2011 | 12:44 PM
billyboy1's Avatar
I've just recently replaced my pads with carbone lorraine pads -well impressed! Great bite and a decent temp range as well. Worth a look at for an upgraded pad
Old Nov 8, 2011 | 12:53 PM
NFSLancerRA's Avatar
I tend to replace my brakes with Elmer's glue and potato latkas.
Old Nov 8, 2011 | 01:06 PM
xi's Avatar
xi
Does the potato have to be cooked or can it be raw?
Old Nov 8, 2011 | 01:19 PM
I tend to fry them on a frying pan. I have found that raw potatoes can be tricky to form into the correct bolt pattern.
Old Nov 8, 2011 | 02:10 PM
So, in all seriousness, if you are looking for Semi-metallic pads, I would go with Hawk HPS. I have absolutely been 100% satisfied with every set that I have run so far. I would also replace the rotors with Centric Premium rotors. That is what I run/ran on my Ralliart.
Old Nov 8, 2011 | 02:12 PM
The GTS pads will NOT fit the Ralliart. You must look up Ralliart specific pads. I believe that the front rotors are the same. The rears are different. To be on the safe side, I would confirm that everything is a Ralliart specific P/N before ordering anything.
Old Nov 8, 2011 | 02:17 PM
Alterna's Avatar
d530 front
Using Stoptech at the moment. Dust comes off rims easier than Hawk or Axxis I've used previously.
Old Nov 8, 2011 | 03:13 PM
xi's Avatar
xi
I tried doing a search and the amount of information/mis information out there is staggering. Lots of part xxx fits me then immediately someone saying part xxx doesn't.
Do you know what part # the fronts and rears are for the hawk pads?
Old Nov 8, 2011 | 03:15 PM
splattj's Avatar
I'm a big fan of CarboTech pads. They have the correct RA specific part.
http://www.ctbrakes.com/pads.asp?Mak...cer_-_Ralliart
Old Nov 8, 2011 | 03:18 PM
jkennedy293's Avatar
The EBC redstuff pads are pretty good too.
Old Nov 8, 2011 | 03:22 PM
Most pad and rotor part numbers can be found here.
Old Nov 8, 2011 | 03:30 PM
Front: HB214F.618
Rear: HB675F.602
I have those two saved in my database, so I am fairly certain that those numbers are correct.
Old Nov 8, 2011 | 03:31 PM
Good luck sifting through that cluster-F.
