having a hard time ordering front rotors
Old Jul 7, 2012 | 04:09 AM
chucknasty's Avatar
bendix gives me 2 different part numbers for front rotors. which is the right one?
PRT5946
PRT6068
Old Jul 7, 2012 | 09:11 AM
stfuad's Avatar
um it does have an application by year/model what year is your car?
Old Jul 8, 2012 | 01:09 PM
chucknasty's Avatar
true, but it goes from 2009 to 2012. kind of throws me off and i know the spacing is different from lancer gts even though diameter is the same. not retrying to order rotors just to send back last time i lost $60
Old Jul 8, 2012 | 06:03 PM
NFSLancerRA's Avatar
The rotors SHOULD be the same between the RA and the GTS. My stock calipers fit perfectly on a GTS.
Old Jul 9, 2012 | 01:22 PM
CFMP RAblue's Avatar
^^INCORRECT^^
I just recently change my front rotors and lost 100 bucks from getting the wrong ones. Althought the GTS and RA are similiar rotors they are different... by milimeters but none the less different.
The RA's are a bit thicker and heavier, I ordered mine thru a local aftermarket shop and got them slotted at KVR performance who got them from Centric.
A set of 4 oem replacement for me was 350 but I wanted slotted so it was 750. Whenever callin a place make sure they go thru the books and look it up as it is different.
Old Jul 10, 2012 | 01:56 PM
chucknasty's Avatar
yes the calipers fit but the threads posted from the swap state that the ralliart rotors have a different offset (hat placement is different)
anyways i went with the 09 ones since it also said outlander and many on here say it is the same as the outlander.
also cost $82 shipped :-)
Old Jul 10, 2012 | 07:09 PM
evo_soul's Avatar
Rotors are different.
Ralliart Rotors
GTS Rotors
Old Jul 11, 2012 | 08:54 AM
Bom's Evo's Avatar
That's funny that the GTS brakes thicker and lighter.
The rotors will fit, but because GTS rotors are thicker, the brake squealers will touch the rotor.
Old Jul 11, 2012 | 01:26 PM
chucknasty's Avatar
i went with the above. looking at them you can easily tell by the gap between hat and rotor surface
Old Jul 11, 2012 | 01:27 PM
chucknasty's Avatar
since the ralliart's are dual piston and thus greater braking force the rotor surface is vented through to the hat (that is what the gap is for) instead of just the OD of rotor.
when buying eclipse rotors i notice certain companies do this for diamante's and not eclipse's since diamante's use single piston although diamante's and eclipse's use literally the same rotor no offset difference.
Old Jul 11, 2012 | 07:08 PM
AlphaKennyBody's Avatar
I've have Upgraded Slotted Rotors on my RA and love them... just saying, Rotors and gonna fit on a GTS or RA doesn't matter in my book...
ryukinevo
Oct 16, 2015 01:49 AM
RallySport Direct
EvoX 'For Sale' Miscellaneous
164
Feb 19, 2014 10:14 AM
Grimgrak
Jan 28, 2014 04:52 PM
RallySport Direct
Vendor Classifieds
26
Jul 9, 2013 03:24 PM
Davo
Jan 23, 2011 02:12 PM
