ABS TCS ASC lights on!!
Old Oct 7, 2013 | 01:36 PM
Speed Devil's Avatar
I took it to be scanned at mitsubishi and it said LOW VOLTAGE ABS PUMP. I cleaned the sensors and topped the braking fluid and they went off but as soon as I stopped and moved again they went on. Disconected the battery for a reset... Turned on the car and the light went off but again once I stopped and moved again they went on....
Some people tell me the hub has a magnetic ring and with the brake dust it messes up the ABS system.
I took out the ABS pump harness and cleaned the pins with contact cleaner, check the voltage of the battery when on and it was fluctuating between 14.3-14.7v.
Old Oct 9, 2013 | 12:46 PM
stfuad's Avatar
find all the power wires to the abs module and check for 12+v
find the grounds and clean them
checking voltage at the battery would only tell you if your alternator was working.
Old Oct 22, 2013 | 03:32 PM
mdrookie's Avatar
I had a same issue. I had changed new hub n ABS sensor wire
mine was under warranty.
mda56
Dec 12, 2015 12:12 PM
moey124
Jun 13, 2015 10:23 AM
Senz118
May 5, 2011 05:27 PM
kmcconn9
Sep 14, 2007 01:25 AM
