Well here it goes........
So the time has come for me to get my new setup for the summer. I got my rims which are 18x9.5 +38. My questions are
-can I get a 255/40/18 with rolling/pulling??? I really hate stretching tires. I can live with 255 or 245 on a 9.5 though
-do I need any camber arms or bolt??. I want to try and keep the camber close to stock as possible so I'm not going through tires. I read somewhere I should get around -2 in the front and around -1 in the rear.
-I heard I need spacers for the rear to get to +35 or less to clear the strut tower so anyone k have a link to some good 3mm spacers?
-am I crazy for trying to run this setup????? Lol
Before anyone tells me to search. I have checked multiple stickies and threads. Couldn't find the right answers.
I'm also dropped on adjustable d2 coilovers btw
"18x9.5 +35 will = front will poke out about 1 1/4" and rears will poke little less then 1 1/2"
Inner Clearance: 21mm LESS Outer Face Position: 43mm MORE
Tires:225/40-18 or 235/40 18 rubbing with stock height
***When Lowered [WILL RUB everywhere even when your stock heigh] SO ROLL THE ALL FENDERS!!!!!!***
***This fitment is VERY AGGRESSIVE, NEED TO rolling and flare out the rear fenders FOR SURE***"
https://www.evolutionm.net/forums/09...s-fitment.html
Close to your +38... So i can only image.
Here is exactly what you need to read. Took 10 seconds to google. Youll need a roll and pull w/ spacers. Youre gonna have to run stretched tires otherwise GOOD LUCK!
http://www.clubralliart.com/showthread.php?t=1756
Honestly I wouldnt suggest it. If you dont pull your fenders out as much as he did you will run into issues. Size difference between the 225 and 245 isnt gonna be noticeable to the naked eye, but if you feel like you need to run wider tires good luck to you. Youre already running a pretty wide wheel so if you plan to go quite low on those coilovers its gonna be rough.
Everybody Ive seen with a Lancer or Ralliart running coils and wide wheels is running between 205s-225s. Why not just skip pulling your fenders and run a smaller tire. You'll save money as well doing so.
heel2toe
12
Mar 27, 2013 10:44 AM
chu
22
Mar 28, 2011 07:52 PM
TKEVO
Feb 2, 2011 08:16 PM
