Wheel Help
Old Jan 11, 2015 | 07:40 PM
Dmarianodesign's Avatar
Wheel Help
Im about to pick up some new wheels and i dont know what would be a better set up. Im currently on the eibach pro kit and assuming il need the fenders rolled but should i get 18x8.5 +38 or 18x9.5 +35? Will i run into any problems fitting the 9.5?
Old Jan 11, 2015 | 11:15 PM
neogeo64's Avatar
it really depends on the tires for the 18x8.5 +38 but if your 235 or narrower then you may not need to roll your rear fenders. the 9.5 you will need to roll your rear unless your running crazy stretched 215 tires (not recommended).
I have 18 x8.75 +35 with 245/40/18 tires and I had to roll the rear only.
Old Jan 16, 2015 | 03:55 PM
So i ended up going with some 18x8.5 +38 enkeis, question is can i put 225/40/18 tires on them since i got them sitting around or should i put 235 or something else on them. Also will i need aftermarket lugs or will the stock ralliart ones work?
Old Jan 16, 2015 | 04:34 PM
neogeo64's Avatar
they will fit, just look a little stretched. you need aftermarket lugs.
tuner lugs aka acorn style
12x1.5mm
doncarbone
Jan 1, 2014 06:17 AM
Go_Lancer_Go
Jul 13, 2009 08:59 PM
macca20042
04-06 Lancer Ralliart How To Requests / Questions / Tips
11
Mar 22, 2005 11:37 PM
Genki
Jul 21, 2004 08:08 AM
LaNceRiTiZ
Lancer Troubleshooting
Jul 6, 2003 03:53 PM
