Completed Evo X Turbo Swap
Old Jun 28, 2009 | 12:55 PM
RallyGoneEvo's Avatar
As Jake26 requested here is my review...
The whole project was fun. Some aggrevating times but well worth it in the end. Things that i used from the Evo X were turbo, manifold, intercooler w. pipes (must have pipes, RA pipes are too long), O2 housing, wastegate, oil and coolant lines, turbo-manifold gasket, O2 housing gasket, and I used an Evo 9 BOV. Things that I was able to swap over were Oil drain line, Air outlet tube, Intake (rig'd up), and Head Gasket. Over all it's an easy project, just time consuming. This is how we did it...
1. Unhook upper IC pipe and take out intake.
2. Take off manifold heat shield and firewall heat shield.
3. Take off belly pan, unbolt downpipe.
4. Unbolt coolant lines and oil drain line. (Have a bucket ready, a lot of coolant comes out!)
5. Undo 2 support brackets, one holding turbo to block and other holding O2 housing to block.
6. Unbolt turbo from manifold and manifold from head.
7. This is the fun part, I put my knees ontop of the radiator cover and wrestled the manifold off the turbo, then wiggled the turbo out.
There is an extra bracket you'll need to take off right about your passengers side axle, it has 2 10mm bolts. Take that off and it's a lot easier to get to the O2 housing-Block bracket bolt.
I could probably do it all in two full days now that I know where everythings at. Swivel heads and a STRONG impact gun are mandatory. The turbo to block bolt is a *****! I had to use a $200 1000ft/lb impact fun with a stiff 14mm swivel head to get it undone.
Old Jun 28, 2009 | 01:46 PM
madcows's Avatar
Good stuff, LancerES... But, uhhh, I would probably use 5W30 instead of 20.
Old Jun 28, 2009 | 04:57 PM
I just use whats recommended for the car.
Old Jun 28, 2009 | 06:05 PM
4g64fiero's Avatar
^^^You say you went ahead and used the evo X head gasket? Why? I thought it was the same part number?
Old Jun 28, 2009 | 06:15 PM
No i meant thats what I didnt have to buy. That I just used the Ralliart one.
Old Jan 19, 2010 | 10:04 PM
CanadianJackal's Avatar
I would like to see some detailed pictures if you have. Can you post or email me if you do. I will be doing the Evo X turbo upgrade in a few months time, trying to put together all the parts and money necessary . Just need to add more info to make sure all goes smooth.
Old Jan 20, 2010 | 04:49 AM
Kieffer87's Avatar
I'm also going to be tackling mine in a month or 2 once I collect all my parts. I think I have a pretty comprehensive list going and have everything needed. There is a post about the AMS ralliart that has a list of everything needed and all the part numbers.
Old Jan 20, 2010 | 10:50 AM
suprPHREAK's Avatar
Getting pumped! My turbo and manifold arrived, O2 housing and BPV on the way!
Old Jan 24, 2010 | 02:36 PM
8urSuby's Avatar
Originally Posted by RallyGoneEvo
Well I know a lot of people wereexcited to see that AMS Performance were the first to do the Evo X turbo swap on the 09 Ralliart. So was I! So I tried it. Finished it last night at 11:30 p.m. Everythings running fine, no CEL or anything. Did run hot to begin with because I forgot to put more coolant in. I changed my oil today with Castrol Syntec 5W-20 as recommended by Mitsu and Fram oil filter. Will be at TTP-Engineering July 14th for dyno tuning. If you likve in or close to Orlando because we might be having a Dyno Day that day. Stay tuned!!!
Congrats!!!! Welcome to the Evo X turbo on Ralliart family!! lol! Yeah trust me don't go anywhere else....
Old Jan 24, 2010 | 04:04 PM
All parts needs are turbo, manifold, oil/coolant lines, O2 housing, wastegate, turbo inlet pipe, intake, and gaskets. I recomend that people wanting to do this swap, search on ebay for evo x oil lines. Theres a kit for $100 that gives you all oil lines and banjo bolts. Stock gaskets switch over.
Old Jan 24, 2010 | 04:10 PM
Kieffer87's Avatar
I seen this kit on ebay but I wasn't sure if it would be comparable to OEM.
Old Jan 24, 2010 | 04:33 PM
Yup worked fine for me.
Old Jan 24, 2010 | 05:41 PM
Bom's Evo's Avatar
He means exhaust manifold gasket i believe. Not to be confused with the cylinder head gasket.
Old Jan 25, 2010 | 04:55 AM
Kieffer87's Avatar
After having this done for awhile do you notice any drivability issues? How about your gas mileage, I would assume it would drop a bit? Any TC-SST issues with the increased torque?
Old Jan 25, 2010 | 06:27 AM
I reused the same cylinder head to manifold gasket. You need a new turbo to manifold gasket.
