Car went WOT
Old Sep 24, 2009 | 07:08 PM
xi's Avatar
xi
Originally Posted by Ladogaboy
Sounds like you were granny shifting, not double clutching like you should.
Should I go back, tear apart the block, and replace the piston rings I fried?
Old Sep 24, 2009 | 07:53 PM
xi's Avatar
xi
Originally Posted by mad_VIII
Sounds a bit like you crossed over a downshift point in the software and when you let off the gas the boost pressure could not vent and got forced into the throttle body after you lifted off the gas.
Check and make sure you don't have any crimps in the blow off valve return pipe (hose that goes back to the intake pipe that vents boost). Only time I have seen revs shoot up when off the gas is when the blow off valve cannot vent and the residual boost gets forced past the throttle plate.
If it is a drive by wire issue, that is very scary. Are you sure you did not have cruise control on or anything????
I gotta go check that tomorrow.
I'm sure i didn't have cruise control on cause the drive was all stop and go the whole way.
Old Sep 25, 2009 | 05:27 AM
suprPHREAK's Avatar
Sounds like you either shifted down when you should have shifted up, OR there is a fault with your pedal sensor. Get the dealer to have a look!!
Old Sep 25, 2009 | 07:33 AM
xi's Avatar
xi
I haven't been able to recreate it.
I swear I didn't mis-shift but I'm not gonna rule it out, i mean anything can happen. Gonna take it in to my dealer at the 10k oil change to have em do the AWC software, fuel line, door rattle, and take a look at it.
Old Sep 30, 2009 | 11:00 AM
Bom's Evo's Avatar
Sounds like shifting it in manual the trans ecu remembered what to do. It learned your shifting points from all the manual inputs.
Old Sep 30, 2009 | 11:18 AM
xi's Avatar
xi
At least it wasn't this!
http://www.reuters.com/article/wtUSI...BrandChannel=0
Old Sep 30, 2009 | 11:25 AM
DatRAzn's Avatar
^lol. I just saw that this morning.
Yes, at least it wasn't your floor mat jamming your throttle open!
Old Sep 30, 2009 | 08:50 PM
xi's Avatar
xi
The lexus that had the accident reached 120mph and the people inside had enough time to call the cops and have a conversation with them. During this time, I wonder why no one thought to slam on the brakes, put it in neutral, or kill the motor...
Old Oct 1, 2009 | 07:17 AM
Bom's Evo's Avatar
Some people don't know what an emergency brake is. Or what neutral on their transmission is. Lexus ask all owners to remove their floor mats too!
Old Oct 1, 2009 | 07:49 AM
DatRAzn's Avatar
This one made me chuckle, same article from http://www.clickondetroit.com/automo...71/detail.html
The Japanese automaker warned owners that if they think their vehicle is accelerating out of control, they should check to see whether their floor mat is under the pedal. If a driver can't remove the floor mat, Toyota advises drivers to step on the brake pedal with both feet until the vehicle slows and then try to put it into neutral and switch the ignition to accessory power.
Why not slap it into neutral, and put it in accessory mode IMMEDIATELY? Then pull over while coasting.
Old Nov 4, 2009 | 05:46 PM
xi's Avatar
xi
http://www.wate.com/global/Story.asp?s=6459687
According to this, putting the Lexus in neutral did NOTHING.
I know the throttle is fly by wire but does anyone know if the transmission (going into neutral) and brakes are also fly by wire? Kinda scary...
Old Nov 4, 2009 | 06:23 PM
Steve93Talon's Avatar
Floormat, my ***. Drive by wire is a scary, dangerous technology. There are reports of several different make and model cars going WOT suddenly with it.
Old Nov 4, 2009 | 09:53 PM
cy08x's Avatar
dang keep posted
Old Nov 7, 2009 | 05:35 AM
Post your stories here:
http://suddenacceleration.com/
Old Nov 9, 2009 | 03:52 PM
Enmitix's Avatar
Just wanted to add something similar just happened to me today, I had the car in sport mode and when I let go of the gas it revved up and made a loud clunking noise, the car kinda jerked forward and felt like a kick in the ***... My RA is completely stock, I didn't look at which gear I was in, but I was going about 60km/h
brads09lancerGT
55
Feb 11, 2012 12:31 AM
DJ Jazzy Death
Lancer Troubleshooting
12
Jan 19, 2011 07:53 AM
Mr Sinister81
Mitsubishi TC-SST Discussion
11
Oct 31, 2010 04:01 PM
xbox4414
Jan 7, 2009 12:04 PM
