THE Complete Evo X turbo swap parts list!
#77
yes, any downpipe that replaces the 02 housing (commonly referred to as 02-downpipe )and is designed for an X turbo will work with the swap and will negate the need for a stock X 02 housing.
#80
If your going to title this "THE Complete Evo X turbo swap parts list!," then please for the love of god, please make it complete!!! Went in to the shop yesterday to do the swap and get tuned, had everything on the list. After sitting at the shop for about 6 hours, they come to tell me there's a problem. The intake won't work, and in order to use an X intake, I will need to either relocate the battery to the trunk, or go with a small battery kit. Also my UICP won't fit, so I'm going to need one of those. They didn't feel comfortable fabricating a custom intake, so they ordered one which won't be in until Monday. Between the extra parts, labor, and the fact that I'm having to rent a car until mines ready, this is costing me an extra $1300. Thank you "THE Complete Evo X turbo swap parts list!"
#81
#82
That sure sounds like a total pain.
If you can put up the part numbers for the required extra stock Mitsu intake items, the OP or the mods can add it to the list.
Rich
Rich
#83
that has been an "issue" for a while. just be glad the core components are all compiled and listed here for you
#84
Since you will need to go with a X intake, you will need to address the battery issue. There are two options, small battery or relocate to the trunk.
You will need an X UICP. Again, since you going to all this trouble, don't even bother with stock.
#85
#86
Well if you read the complete thread the parts list on the first page is very complete. The small battery kit I believe somewhere in this thread states you need this and I believe the only other part that you need was the Evo X Maf housing unless you use AMS's intake kit. As for the UICP the stock X pipe is needed and you should have had this and the LICP with at least a STOCK X intercooler before you did the conversion. Everyone here has contributed time and knowledge no reason to thank everyone at once with a slap in the face ;-)
I followed a thread titled "THE Complete Evo X Turbo swap parts list!" thinking that the capitalized THE and the exclamation point at the end meant that this would be absolutely everything I would need. In the end it wasn't and the mistake is costing me $1300.
I don't completely blame the parts list, I blame myself as well as the shop who decided to do 75% of the work before realizing things weren't going to fit. I just feel like a good bit of the extra expense that's coming out of my pocket could have been avoided if the parts list had been better updated.
I'm done ranting
#87
I have the stock x intercooler, but I was using an aftermarket RA UICP. I have the X MAF housing. I was confused about what was needed to attach the MAF housing to the turbo, so I asked specifically on page 5 of this thread three weeks ago, the question recieved zero response.
I'm done ranting
I'm done ranting
I understand your venting/ranting as I went through the same swap and all I was missing was the MAF housing and thank god I could find one used local as I had already planned to use the Cobb SF Intake. What you needed to connect to the turbo is a Turbo Inlet Hose just so you know :-) which is listed in my signature if you would like to take a look.
#88
You will need an evo x intake, if your going as far as to swap turbos, then you might as well just go aftermarket rather than paying top dollar for a restrictive set-up.
X UICP is not required for the turbo, just required if you upgrade to X FMIC (which everyone should anyway)
but just to clarify for others - a small battery swap willl only allow fitment of some SRI's (only confirmed I know of are AMS, Cobb SF, and AEM without box). Anything using the OEM-style box (OEM, AEM) still won't fit
dont' forget OEM X spark plugs (different heat range)
edit: updated, thanks spider21
#89
not sure what you mean by "paying top dollar for a restrictive setup". if you're trying to say the OEM X intake is really restrictive, it's not. please don't spread exaggerated statements (and they're not expensive either)
but just to clarify for others - a small battery swap willl only allow fitment of some SRI's (only confirmed I know of are AMS and AEM without box). Anything using the OEM-style box (OEM, AEM) still won't fit
