Intake Questions
Old Dec 3, 2009 | 02:47 PM
RalliSGT's Avatar
I can tell you that we use K&N type filters on the helicopters we took to the desert and beat the crap out of them and they held up really well! After that I had to buy one for my RA and i love it!
Old Dec 4, 2009 | 10:49 AM
Psycho09RA's Avatar
So I just had a thought regarding aftermarket intakes and how they lean out the AFR without getting a tune:
Since the RA recirculates the boost back into the intake via the bov/recirc valve and the RA is expecting the extra air flow from the boost recirculating, would there be any ill effects by using a BOV that vents to atmosphere in conjuction with an aftermarket intake?
My thought is that since an aftermarket intake used with a BOV that recirculates back into the engine is leaning out the AFR mixture to undesirable levels, maybe using an aftermarket intake and a BOV that vents to atmosphere will provide the needed airflow that will keep the AFR in check. The only downside to this theory, at least that I can think of, is that it may not provide an increase in performance.
Any thoughts on this theory?
I'm just thinking out loud.
Old Dec 4, 2009 | 01:06 PM
RGRA's Avatar
Hypothetically, yes they counter act each other, but...2 wrongs don't make a right. You would still have to much airflow through the aftermarket intake for the maf to measure, and the bov would have to dump the exact same discrepancy in air pressure to compensate for it, which will vary depending on how much your a boosting...
Old Dec 4, 2009 | 01:16 PM
Psycho09RA's Avatar
Crap! You're right, I just realized that there still would be a high AFR while the engine is boosting and the only time AFR would possibly be countered by the BOV, assuming the BOV is compensating enough, is when the excess pressure is vented.
Old Dec 12, 2009 | 05:25 AM
lookitznite's Avatar
Where can I get a k&n drop in filter?
Old Dec 12, 2009 | 08:48 AM
kaiten2's Avatar
Autozone pep boys any major parts store should carry them
Old Dec 13, 2009 | 12:13 AM
lancera's Avatar
If you have to get a filter i recommend a hks drop in filter. I heard you can hear the turbo a lot more and a little hp increase too.
Old Dec 14, 2009 | 09:07 AM
but ever since i've installed my UR intake i took apart the whole filter thing...lol what should i do now?
C H's Avatar
C H
The HKS seems like a good filter, however it is an expensive throw away filter. They are $45 and are meant to be changed just like a regular filter and not suppose to be cleaned like the K&N
Old Dec 14, 2009 | 09:37 AM
RGRalliart's Avatar
For that I'd find a way of cleaning and reusing or I'd stay away from that filter.
Old Dec 15, 2009 | 05:15 PM
C H's Avatar
C H
Apparently some people have cleaned it, but probably only once or twice before the foam starts falling apart and going in you engine
Old Dec 15, 2009 | 05:24 PM
Skym's Avatar
Ouch... that doesn't sound too good...
I have the HKS filter and I'm very satisfied with it. It's recommended to be changed at 10,000 miles. Thats about 1 filter in 4 months if you do lots of driving.
$45x3= $135 a year.
Old Dec 16, 2009 | 07:25 AM
soo wut the hell do i really have to get a tune for the UR INTAKE?!!!? Btw guys what do i do ? I havn't changed the filter ever since i had the ur intake... how do i clean it? do i just go and buy a different cone for it? Please help!
Old Dec 16, 2009 | 08:18 AM
Taranis's Avatar
Comes down to whether or not you want to trust what the company says about their product. Unfortunately every car will behave slightly different with the same product, so there is no way for anyone here (or at the company) to guarantee you anything. =/
-Taranis
Old Dec 17, 2009 | 10:01 AM
Anyone know how to clean the UR intake filter? (noob question alert) :P
