Turbo Flutter???
Old Dec 25, 2009 | 06:54 AM
RallyGoneEvo's Avatar
Turbo Flutter???
Hey guys, sometimes at real weird occassions I'll get a turbo flutter while shifting. I'm running the OEM X Setup with Ultimate-Racing Short ram and Evo IX BOV. Could it be that the BOV isnt adjusted right? I'm thinking about ordering an Agency Power bov after New Years.
Old Dec 25, 2009 | 07:25 AM
07outty's Avatar
you could try adjusting the waste gate accuator.
Old Dec 25, 2009 | 09:01 AM
boondoc's Avatar
i'm running a similar intake set up. and mine flutters sometimes during shift.
Old Dec 25, 2009 | 09:12 AM
How can I fix it? And how do I adjust my wastegate?
Old Dec 25, 2009 | 12:04 PM
07outty's Avatar
take off the exhaust manifold heat shield.
look down toward the turbo inlet. you will see the arm going from the waste gate over to the actuator.
unclip the clevis from the waste gate and turn ( tighten) the clevis a turn or two.
put the clevis back on the waste gate and go for a drive.
the waste gate will stay closed, longer/tighter.
Old Dec 25, 2009 | 04:26 PM
Which way tighten and which way loosens?
Old Dec 25, 2009 | 08:19 PM
Groundfades's Avatar
you dont need to fix the flutter.
is it causing issues with performance? I hear it, my srt-4 had it alot louder and all the time. the flutter is cool
Old Dec 25, 2009 | 09:11 PM
ambystom01's Avatar
I'm sorry but how will adjusting your wastegate, the part that dictates how much boost you make, have any effect on turbo flutter? How do you even know you're experiencing true turbo flutter? If all you're noticing is additional noise, it's likely the intake. Are you tuned for it? If no, that could raise issues. If it's true turbo flutter, that's generally caused by the BPV malfunctioning causing pressurized air to essentially slam into the vanes of the turbo, slowing it down.
Old Dec 25, 2009 | 09:29 PM
is he referring to the surging sound. I get it all the time, thats not a wastegate flutter LOL.
Its a small turbo, heard it many times before on many cars, and the sound is there regardless of weather you have an intake or not, the intake just lets us hear it.
Old Dec 27, 2009 | 12:52 PM
Its not a small turbo, its an X twin scroll. And it only happens right after shifting, so it very well could be the BOV. But Idk how or if you can adjust a stock IX bov. Any advice?
Old Dec 27, 2009 | 02:00 PM
ambystom01's Avatar
What happens?
Old Dec 27, 2009 | 02:40 PM
how long does it take to get an fp red in, you claim to have had it ordered for months now..?!
Old Dec 27, 2009 | 05:30 PM
Like once I shift from 4th to 5th or 5th to 6th, right after I shift my boost drops and it bounces irratically and makes a ss-ss-ss-ss-ss sound. and I decided an fp red for now cuz I'm trying to get a widebody from PR or Singapore, and I'm waiting on more SST upgrades.
Old Dec 27, 2009 | 10:15 PM
ambystom01's Avatar
Are you tuned specifically for the intake? I don't see anything in your setup that would indicate you're maxing out the BOV, if it is the BOV, it's either installed incorrectly or broken. I see no reason to spend big bucks on a new BOV when you could easily just get another IX or X BOV on here for cheap.
Old Dec 28, 2009 | 05:45 AM
Well what most likely is the cause?
