Using EcuFlash and the GST basemap
Old Apr 20, 2010 | 03:42 PM
lostirc's Avatar
Hey Everyone,
So I just got my tactrix cable and I've been trying to load the 2010 Ralliart GST basemap.
The issue I'm having is when I try to open the GST Rom I get a prompt saying that EcuFlash can not recognize this ROM using any current definitions. I'm using version 1.42.2595
I tried searching around for a definition but I haven't been able to come up with anything so sorry if this has already been solved
Old Apr 20, 2010 | 06:12 PM
lostirc's Avatar
So after some more searching I was able to find the info I needed to fix this. Figured I would post here so anyone else with the same issue won't have to dig through the forums.
To fix the error when loading the 2010 maps I followed this post:
https://www.evolutionm.net/forums/ec...sportback.html
I re loaded the image and everything loaded correctly. After loading the new ROM I cleared DTCs from OpenECU and everything is now working great.
Old Apr 20, 2010 | 09:50 PM
GST Motorsports's Avatar
Glad you got it working correctly. When I get some time I will post the XML files for each rom to make sure people do not have issues.
Any feedback on the basemap?
I am a fellow 2010 sportback owner now so expect basemap updates soon!
- Bryan
Old Apr 21, 2010 | 08:56 AM
velocityhead's Avatar
Bryan, does this also mean there will be updates for the 2009 basemaps? I don't know how many differences there are from 2010 model year.
Old Apr 21, 2010 | 09:09 AM
RotorGlow's Avatar
I would guess ZERO difference.
Old Apr 21, 2010 | 11:35 AM
lostirc's Avatar
- Bryan
So far its great! I'm using the map without a new boost pill and even without it I definitely notice a performance boost. Seems like this is the map our cars should have came with from the factory
I think I will pick up a boost pill from you guys soon. My only concern is returning the car to stock for dealer visits.
Old Apr 21, 2010 | 11:46 AM
Psycho09RA's Avatar
As long as your dealership doesn't find out somehow that you've flashed the ECU and changed the boost pill you should be fine.
Old Apr 21, 2010 | 12:02 PM
Slee256's Avatar
I always flash my car back to the factory map and put in the stock boost pill before going to dealer for any recalls/warranty stuff.
Old Apr 21, 2010 | 01:03 PM
lostirc's Avatar
Great! I just ordered the pill from GST, I can't wait to get it in
Old Apr 21, 2010 | 02:13 PM
Psycho09RA's Avatar
You won't be disappointed!
Old Apr 21, 2010 | 02:54 PM
Well, the reason I ask is because he has separate maps for 2009 and 2010 models.
Old Apr 21, 2010 | 06:36 PM
Any updates will span across the model years and regions.
There are seperate maps for model years and regions because the ROM ID's are not interchangeable between regions and model years
- Bryan
razorlab
5165
Aug 11, 2024 07:56 PM
Quiko00
Jan 24, 2016 04:14 PM
danike
May 1, 2014 08:41 PM
Rall1boy
Mar 29, 2013 02:07 PM
rall1rt
Sep 22, 2010 10:15 AM
