Ultimte Racing (UR) Downpipe and HFC
Old Aug 18, 2010 | 12:02 PM
RalliX's Avatar
Here are a few pics and weight of the UR Downpipe & HFC (metal).
UR Downpipe ~ 4 lbs.
UR HFC (metal) ~6.3 lbs.
Hope everyone here finds this info useful.
Attached Thumbnails Ultimte Racing (UR) Downpipe and HFC-ur-dp-hfc.jpg   Ultimte Racing (UR) Downpipe and HFC-ur-dp-01.jpg   Ultimte Racing (UR) Downpipe and HFC-ur-dp-05.jpg   Ultimte Racing (UR) Downpipe and HFC-ur-hfc-01.jpg   Ultimte Racing (UR) Downpipe and HFC-ur-hfc-05.jpg
Old Aug 18, 2010 | 01:17 PM
zx-319's Avatar
Did the down pipe came wrapped like that?
I just bought one used and it wasn't wrapped. Is there any significant benefit to do so?
Thanks,
ZX
Old Aug 18, 2010 | 01:54 PM
RalliX's Avatar
It wasn't wrapped when I bought it new.
But I wrapped it myself to minimize the radiating heat getting into the engine compartment.
Old Aug 18, 2010 | 03:16 PM
zx-319's Avatar
Hum, then I should have done the same... Is it possible to cover the flange too?
I'm in Canada and winter are really bad on the bolts... Would help to protect it if it's feasible :P
Old Aug 19, 2010 | 08:36 AM
robyn402's Avatar
question is do you throw CEL with that cat setup?
Old Aug 19, 2010 | 08:40 AM
SHAWN325's Avatar
my CEL goes on and off all the time from the O2 sensor, does wrapping the down pipe help that. I was going to buy the AMS extention to stop the CEL.
Old Aug 19, 2010 | 09:05 AM
lchu's Avatar
My CEL never turned on with my set up. *touch wood*
Old Aug 19, 2010 | 09:08 AM
DaJackson's Avatar
The CEL would be from the O2 Sensor seeing different A/F readings than what the car is programmed to accept. Wrapping the pipe shouldn't affect that as its intended to control heat.
Old Aug 19, 2010 | 09:26 AM
RalliX's Avatar
Never have issues with CEL since I installed and Idon't have to do any mods.
Just direct replacement.
Old Aug 19, 2010 | 09:44 AM
RalliX's Avatar
It may be possible to cover the flange, but there is no point covering it.
If you're concerned about the bad winter weather on the bolts, try using the high corrosion resistant bolts such as 18-8 stainless steel grade bolts.
Old Aug 19, 2010 | 11:18 AM
S2K2EVO's Avatar
Is that hooked up to your stock exhaust? Any video clips to show us how it sounds?
Old Aug 19, 2010 | 01:02 PM
robyn402's Avatar
so with the downpipe and metal HFC on your car no CEL codes... how long has it been on the car
Old Aug 19, 2010 | 07:41 PM
RalliX's Avatar
Yeah. It's hooked up to the stock exhaust.
The combination of DP & HFC sound much better than the stock for sure. Not too loud.
I'll try to post video with sound later.
Old Aug 19, 2010 | 07:45 PM
RalliX's Avatar
That's right. No CELL codes.
Been running for almost 1k miles.
Old Aug 19, 2010 | 09:40 PM
robyn402's Avatar
good to hear i'm looking at buying those parts, good to hear they actually work at keeping the codes away
