gst+sunroof
You're gonna kill you cluches if you do that.
Don't you feel you car front lifting a little? That because the clutch is engaging and tries to move the car but fails to because you're holding the breaks so your clutch start slipping.
Trying quickly tapping the gaz pedals to bring the RPM to 4K RPM and then hold the gaz... This way seams to be safer for your clutches...
Our cars are NOT drag race cars so they are not built to do launches. They can do it, they survive it. But each time you do it, you wear your clutches much more that when you do normal starts.
