ams o2 spacer
Old Sep 27, 2010 | 03:52 AM
bsvaton's Avatar
Question ams o2 spacer
Ok so after I finally got everything on the cel comes back. The thing is it only comes on when I stop at a red light. I am on the middle restricter plate now. So I am trying to figure out if I should try the smallest next or the largest . I am think the back pressure when coming to a stop is the problem . Any feedback would be appreciated.
Old Sep 27, 2010 | 05:08 AM
zx-319's Avatar
I had the CEL too because of my test pipe. I used a O2 Space from Vibrant (I think it the same as AMS). I used the larger ring (there were included in the package) and my CEL is gone.
Did you try this one?
Old Sep 27, 2010 | 07:14 AM
Bom's Evo's Avatar
My CEL comes on even with the spacer. Longest it stayed off would be probably 3months. I have a hi flow cat too...Sucks. I'm using the smallest pill.
Old Sep 27, 2010 | 07:16 AM
03chi-town0Z's Avatar
depends on which code you're throwing. if it's a catalyst efficiency code, you need the smaller opening. if you throw the 02 sensor code, you need the larger opening
Old Sep 27, 2010 | 08:56 AM
robyn402's Avatar
do you have tuning software? i have accesstuner race and you can modify the map settings like turning off the rear 02 sensor... maybe have ams send u a modified version of your map with that done?
Old Sep 27, 2010 | 09:40 AM
bsvaton's Avatar
I have a code reader let me find out which one it is throwing. Thanks for the info my mind was set on the 0420 code but I was not even thinking about the cat eff code. Very helpful.
It is just weird that it works fine while under throttle and when I start it up but when I come to my first stop it pops on. I will post my findings.
Old Sep 27, 2010 | 02:12 PM
stfuad's Avatar
P0420 is the cat efficiency code I believe. maybe P0401? or is that a lean/rich condition?
Spending too much time with Fords P0401 is a EGR flow code.
Old Sep 30, 2010 | 05:59 PM
bsvaton's Avatar
OK so I swapped out the middle restrictor for the smallest one and the CEL has not returned I hope I am not giving myself bad luck by posting this but I will see how long it lasts.
Old Oct 1, 2010 | 10:40 AM
Kieffer87's Avatar
Keep me posted I also have P0420 with my TP and would love to get rid of my CEL.
Evo_Goodness
Jun 23, 2016 01:34 PM
Dimonstva
Lancer Tranny/Drivetrain Tech
Mar 23, 2016 10:40 AM
coreymelton
May 16, 2015 05:41 AM
my3000gt
24
Oct 23, 2005 05:11 PM
BlownIncome
18
Oct 5, 2004 10:40 PM
