need a QUICK answer TUNE TODAY!!!
Old Oct 13, 2010 | 08:39 AM
2010 Rallihead's Avatar
A NEWB IN HELP.. MY TUNE IS IN 2HOURS!!!
Do I need to upgrade the fuel pump for my tune, cause the tuner shop that I'm going to is telling if I wanna max out the Turbo, the tune is gonna require a Fuel pump, and ofcourse a boost controller, he also said he recommend me buying a new set or spark plugs that he has Evo drivers use when he tunes them something to do with the heat, guessing they're iridium which is not bad for $43
my question is do i really need the upgrade the fuel pump, isn't the fuel system, the same as the evos?
MY current upgrades are CONE intake, SSvQIII BOV, 3in Turbo - back then ofcourse if you throw in the two other things this guys is suggesting then I would also have the spark plugs and fuel pump
Old Oct 13, 2010 | 08:53 AM
TOralliart's Avatar
I think you will max out the stock ralliart turbo before the fuel pump. If you upgrade to a larger turbo, then you may need to upgrade the fuel pump.
Old Oct 13, 2010 | 08:59 AM
Magnus82's Avatar
My tuner has never suggested upgrading the fuel pump or a boost controller. Unless they changed something for the 2010's, the RA comes with Iridium plugs. I changed my spark plugs just for ***** and giggles but I'm just running OEM Evo X plugs.
Oh, and I am running the X turbo.
Old Oct 13, 2010 | 09:19 AM
so I should just get a tune and not worry about the fuel pump and plugs, but wouldn't i need a Boost controller? to bring up and the boost, for times when the max boost I can achieve is not needed, like if I race then I raise it and if I'm just cruising I can lower it?
Old Oct 13, 2010 | 09:22 AM
What kind of numbers do you all except I'll make with this setup, stock I was 192/212.. and I put on the intake, BOV, exhaust, but stock piping and Front mount. Maybe between 260-280 WHp and 260-290 WTq?
Old Oct 13, 2010 | 09:34 AM
total0wnage's Avatar
I heard somewhere that boost controllers arent supposed to be used with the SST, cause thats what the boost pill is for. Get a pill and then have them tune it with pill.
Old Oct 13, 2010 | 09:41 AM
Thats right I remember reading about that on AMS's website, thanks for bring that to my attention. LOL but were can I get one in a hour??
Can a tune be done with out a pill or Controller? just strictly ECU? or does it need something to regulated like one of these two, cant they set up a safety on th ECU to know when to regulate?
Thanks again totalownage, this is were I remember reading it http://www.amsperformance.com/cart/A...oost-Pill.html
Old Oct 13, 2010 | 09:45 AM
Theres any way I can find a Boost pill at any shops? around houston?
Old Oct 13, 2010 | 09:55 AM
GST Motorsports's Avatar
Stock fuel pump is fine for ANYTHING the stock RA turbo can dish out on pump gas.
RA spark plugs are 1 step *warmer* then the Evo 10 plugs. FYI
For stock turbo, they are fine, upgrading to larger turbo, I would swap to Evo 10 heat range.
The stock ecu is a better boost controller then almost anything currently on the market, and it came with the car.
- Bryan
Old Oct 13, 2010 | 09:56 AM
RA spark plugs are 1steph *warmer* then the Evo 10 plugs. FYI
- Bryan
so I would have to cancel the tune till I get this pill to come in?
Old Oct 13, 2010 | 10:09 AM
thanks guys I just canceled the tune for 3-5 days till the Pill comes in!!
Old Oct 13, 2010 | 11:29 AM
jkennedy293's Avatar
If you ordered a GST pill, I would plan on 2-3 weeks, unless something has changed recently and they have improved their order processing.
Old Oct 13, 2010 | 11:34 AM
TOralliart's Avatar
Yeah. They've been having some issues with their ordering system.
Old Oct 13, 2010 | 01:16 PM
Westbound&down's Avatar
240 whp 270 torque.
and you do not need a fuel pump
Old Oct 13, 2010 | 09:31 PM
Menendez's Avatar
Ya my boost pill never came in, I just received an envelope with an invoice and no boost pill lol. There was a small cut out hole so I think someone stole it, possibly the mail man lol. I didn't even want to bother because it would probably take another 2 weeks to get one from GST so i just got a grimmspeed 3 port boost solenoid from a friend. That is another alternative from boost control
