Confirmed : SST 1st gear throttle limit MR vs RA
Thought you guys would find this interesting.
https://www.evolutionm.net/forums/ev...-mr-vs-ra.html
- Bryan
- Bryan
Interesting indeed. So could this be part of the reason why its harder for the MR guys to break the 11 sec barrier whereas we have some RA's in the low 12's with less power?
very interesting. Bryan you should get ahold of the guy with the RA running around with the MR trans. This might be a simple way to tell if this is ECU or TCU controlled since he has RA ECU and MR TCU/trans.
