UR straight pipe and high flow cat
Old Feb 23, 2011 | 03:17 PM
Krisko's Avatar
I just got my UR high flow cat and downpipe in the mail. It seems the UR straight pipe that I had already is about a foot longer than the high flow cat. Is this right? I thought the hfc was suppose to replace the straight pipe or do these attach to one another?
Old Feb 23, 2011 | 03:23 PM
RalliX's Avatar
UR HFC and Straight Pipe should be the same.
I think you might get the wrong one. Call them up.
I have the same setup DP and HFC. No fitment issues.
Old Feb 23, 2011 | 04:01 PM
Krisko's Avatar
UR straight pipe and high flow cat-183775_10150097461843437_508863436_6381317_444238_n.jpg
The smaller pipe is the hfc. The longer bronze one is a straight pipe
Old Feb 23, 2011 | 05:55 PM
jan_ralliart's Avatar
something s wrong, i had both UR high flow pipe and catless pipe and they have almost equal length
Old Feb 23, 2011 | 06:03 PM
ArtofRalli's Avatar
A tad off topic, but when installing the CB is the resonator against the cat or opposite to?
Old Feb 23, 2011 | 09:34 PM
sstevojr's Avatar
s/b opposite (toward the rear/muffler) on most set-ups. Dont know about their's tho, but usually it can only fit one way due to drive shaft clearance.
Old Feb 23, 2011 | 09:37 PM
sstevojr's Avatar
How did you have that straight pipe installed before, seems too big to have replaced the stock cat (or conversely, the hfc is WAY small messing up proportional perspective)?
Old Feb 24, 2011 | 04:01 AM
03chi-town0Z's Avatar
based on the size of the downpipe sitting next to the hfc, i'd say the straight pipe was never installed on the car and is probably for an evo 8/9 setup, and the hfc is the proper size. just a guess though.
Old Feb 24, 2011 | 07:21 AM
Krisko's Avatar
Im having work down to my car tomorrow and I wanted to make sure all parts were there. UR was closed when I got the parts. The longer straight pipe and the bent curved pipe /w mini muffler are both the midpipe because its a two part design. I called them up this morning and they gave me that answer. So everything is there. Thanks guys.
Old Feb 24, 2011 | 10:14 AM
That makes sense now, the downpipe is new design which is longer n the cat pipe is shorter to work with it
So looks like that long downpipe won't fit oem exhaust And that cat pipe won't fit oem downpipe neither
Old Feb 24, 2011 | 05:34 PM
aah, i didnt realize they were including a midpipe with it. that explains a lot
FoxFMX
Apr 29, 2016 07:22 AM
Silver09RA
26
Jul 24, 2014 10:05 PM
yenny
Jul 17, 2013 02:28 PM
bossssman38
Feb 15, 2013 06:32 PM
dannyz
Jun 17, 2009 07:57 AM
