High flow cat vs resonated test pipe, which is quieter?
Old Sep 23, 2012 | 12:02 AM
yenny's Avatar
I have an AMS tbe that had a straight through test pipe. It was too loud so I installed a resonated test pipe. Still too loud.
Wondering if a high flow cat would be any quieter than the resonated test pipe?
Also, is it possible to run both a hfc and resonator together on a tbe?
trying to figure out how to quiet the beast down, as quiet as possible
Old Sep 23, 2012 | 12:28 AM
Chaser_41's Avatar
Hfc would be more quite I would imagine. And anything can be done with the power of welding
Old Sep 23, 2012 | 12:50 AM
ccampbell's Avatar
A HFC might be a little bit quieter. And yes you can run both inline. My suggestion is to look into putting a muffler in your test pipe location. I know buschur and ultimate racing both sell them or you can get a magnaflow muffler and weld it in there which is what I did. Resonators mainly change the tone of it, like getting rid of raspy sounds.
Old Sep 23, 2012 | 08:27 AM
killerpenguin21's Avatar
my berk hi flo cat is much quiter than my megan resonated test pipe. i lost less than 5whp and my head doesnt explode after long drives anymore.
Old Sep 23, 2012 | 09:44 AM
evo8426's Avatar
Did you use the AMS resonated test pipe? It is what I run, I tried to go with their straight test pipe a year ago and took it off in less than 20 miles to run the resonated pipe.
Old Sep 23, 2012 | 12:05 PM
blknblubkrdude's Avatar
A resonated test pipe will only be minimally quieter than a standard pipe.
A cat is what really quiets things down.
But... you then add weight, increase spool times and EGT's, while decreasing power and fuel economy.
Old Sep 23, 2012 | 12:11 PM
sujinX's Avatar
get a cat, quiets it down and saves the environment. dont be one of those guys...
resonators change tone, mufflers help quiet things. but quiet is different for everyone.
Old Sep 23, 2012 | 02:49 PM
yenny's Avatar
Hmm so it sounds like a HFC will be quieter than the resonated TP. I'm ok with some loss of whp and increased spool times
Yea I took out the AMS test pipe and put in a resonated ams test pipe. Since it still too loud for my tastes, Im thinking of switching to their HFC to see if it quiets things down some more
Old Sep 23, 2012 | 05:14 PM
Grimgrak's Avatar
Do what I did and discover the apexi ats silencer 115mm, with a SP engineering boost acutated cut out. Driving around town the car is quiet and low profile like a camry. Past 4psi it starts getting loud. If you dont want the cut out to activate you just disconnect the vacuum line.
Old Sep 23, 2012 | 05:22 PM
EdSales's Avatar
I've heard that AMS's exhaust are loud in general. There was another thread where someone said to replace the AMS Muffler with another one.
Old Sep 23, 2012 | 07:19 PM
Boosted Tuning's Avatar
HFC for sure.
Old Sep 23, 2012 | 07:36 PM
yenny's Avatar
anyone know which catback would be a direct bolt on fit?
Old Sep 23, 2012 | 11:29 PM
evo8426's Avatar
Nothing but AMS or custom made will bolt up to their exhaust
Old Sep 24, 2012 | 10:56 PM
Seto519's Avatar
im running a catco hfc on my ams tbe
Old Jun 27, 2013 | 07:37 AM
Nobeam's Avatar
I'm trying to decide between a AMS resonated test or a ETS high flow Cat with my ETS V2 quiet.
